1 - 15 of 15 Posts
I have a lead on a KTM that I can get in trade. It's supposed to be a 2003 525EXC motor with a 2004 frame swap that is currently registered and plated with a good title. It has Baja Designs kit as well as factory horn and signal switch on the bars. Has a desert tank and an exhaust installed. Black Excel 21/18 dirt rim setup. Includes factory seat and tank. Also a spare bottom end... Try and make a deal or run away? Also, what's it worth?
Last pic is off the engine case - above that is the VIN on the neck...
I would run both numbers to see witch one is hot. If all checks out good I'd offer him 1,500. No doubt he will think it's worth 5k. It was 5k new.
The VIN checks out clean and he has the title. I can't figure out how to check the partial off the motor. I also want to know what year and specs on the motor/trans...
So I'm trying to work out a trade. I have a factory 2wd 1978 Blazer that I have about $3200 invested. I'm going to try and get the KTM, which I didn't know was assembled from 2 bikes, an his brother has an 2004 WR450 as well. Our DMV doesn't want to issue him a title because the dealer name on the front is different from the back. Something to do with the dealer changing names. I haven't seen a copy the title for the WR450... I figured that if I could trade the truck for both bikes it would be a good deal even if I have to fight with the DMV.
Yes Pinepig i do realize the date code on the motor. Motors have the year/family/assemble number stamped on them as they are being assemble on the line. And frames have the model year stamped on them. Meaning if the bike was assembled in late 03 being rolled out as a 04 bike it would have an 03 motor in it. Or is it just us American manufactures that do this?:headscrat
According to the OP the engine number comes back to a 525 EXC, you can see on the frame where somebody wrote MXC.
D'oh, my bad, I did see that. Looks like a salvaged frame. In my business it is not uncommon to see prior years motors in trucks, as long as it is CARB approved. Other components can be all over the place. I seen a new lift that had 20+ year old crap in it, all new, just not current production.
Sent from my XT1254 using Tapatalk
Discussion Starter #11
the guy said he got an eBay frame and title to get it plated...
... I should have asked where the spare bottom end came from...
Does the Nevada title have the motor number on it, most likely. Has it been changed to reflect the current frame/chassis info? Stolen then bought frame to try and register it?
Discussion Starter #13
I actually didn't notice.... I'm not going to trade for just the KTM and the WR450 need the get the title straight before I try and make a deal.. I'll revisit that later...
Meanwhile I'll start looking for another trade...
I don't know how bad the DMV is to work with there, but if it is anything like California's it's lame as hell. Most people will straighten out the paper work before hand because it raises the value of the bike, unless it is a no go at the DMV. Then they fabricate stories of how easy it is to fix. If it was easy they would've done it, especially if they have owned it for any length of time. Here we get the flippers that will by an Arizona bike and try and sell it here only for people to find out our DMV hates bikes from Arizona.
I bought a new 520 in 2002 it was just at 8k, they are not cheap but mine is Still down stairs working fine
1 - 15 of 15 Posts
