hey there junkies,just bgot a 2009 drz 400sm and will be doing 3by3 mods.is the hole size you cut in the airbox actually 3inch by 3inch or is it bigger.you tube video seems like the hole is bigger than 3 by 3.help please
It should be 3 inch by 3 inch for a total of 9 sq in....Just get a small ruler and measure around the opening where the snorkle was located. I used a vise grip holding a razor and heated up the razor using a blow torch. It cut through that plastic like butter and left the edges mostly smooth with no shavings or mess...Good luck and take your time
