everyone says to use a vise grip with a razor heated up with a torch to cut the 3 by 3 hole in the airbox.how about a dremel tool with a cutting wheel.has anyone used this
bx cutter and a torch works great. a dremel tool will look like crap and get plastic everywhere
Dremmel will work,but leaves Alot of particles and could get in carb.
Get a 3" paint scraper and heat it. When it's hot enough it will push through plastic. Clean and easy. Be sure to pre mark the 3x3.
I just used a hair dryer, heated up the plastic, and cut through it with a box cutter. Worked great, made no mess, and cut easily.
