So i recently bought some new Pro-Taper clamp on / lock-on grips for my 2016 701. Clutch side fitting was a breeze. Problem i have now, the throttle doesnt fit with the RBW unit, and i can in no way figure it out. Am i being stupid and is there an easy fix, or did i waste my money on the grips.
Super Moderator
does the grip set specifically say it's for your bike?
if not you probably wasted your money. lock on grip sets come with a throttle tube and cams to make them work on bikes that still use a cable to the throttle body or carb. 701 is drive by wire so it won't work on the throttle side.
