I recently picked up a Brembo RCS master for my 2018 701. Because of the 90 degree on the front brake line one needs an adapter. Turns out this adapter is back ordered.
Solution...remove the ABS and run the lines how they should be - directly to the calipers.
For those that have removed it. Did you have custom lines made or could you match something off the shelf? I figure it shouldn’t be that hard to find a dirt bike line that would work. Mine can’t have the 90 degree at the top though.
Discussion Starter #2
If anyone else has a 701 and installs a Brembo RCS master and also deletes their ABS you can grab off the shelf lines from 2017ish Honda CR450r. Just finished mine up.
Nice. I can’t wait to try mine. Might break quarantine to see how it is.
I got the RCS14 for mine. What setting do you run yours on?
Or.. if you're wanting to maintain the ABS with your factory brake lines, pick one of these up:
