I was out today with some friends around town, as I rolled onto one of the highways my instrument cluster lit up like a christmas tree, All the indicator lights came on, needle went from 0 RPM to redline, then back down, just like it does when you turn on the key, then went dead.
I coasted to a stop, checked my all fuses, engine kill switch and battery connections, but nothing worked. The entire electrical system is dead.
Ive got ~450 miles on it. Dealer is closed till tuesday, This happen to anyone else?
Any ideas to try?
I figured it out.
It was a clip that secured the main fuse and some connector, it got loose.
was going to say, if it looked like it did when you started it up, then it lost power for a sec and then came back on, so had to be a loose connection....well usually
