Real quick as I'm not at home; what type of valve adjustments does 610SM use?
Michelangelo · Registered Joined Aug 25, 2004 · 2,688 Posts Discussion Starter · #1 · Jun 6, 2008 Only show this user Real quick as I'm not at home; what type of valve adjustments does 610SM use?
siam · Registered Joined Sep 12, 2004 · 1,599 Posts #2 · Jun 6, 2008 Only show this user a screw with a nut :lol:
Michelangelo · Registered Joined Aug 25, 2004 · 2,688 Posts Discussion Starter · #3 · Jun 6, 2008 Only show this user LOL. Doh I just found this. http://www.supermotojunkie.com/showthread.php?t=58563 So does anyone know then if the 2005 TC250/450 uses shims then?
siam · Registered Joined Sep 12, 2004 · 1,599 Posts #4 · Jun 6, 2008 Only show this user shims 9.48mm for the 450 not too sure bout the 250 might be the same since they made all the valve stems a bit more beefy durring 05 then on
xNORCAL2500HDx · Registered Joined Feb 24, 2007 · 1,451 Posts #5 · Jun 6, 2008 Only show this user im 90% sure sure they use the same size shims.
