Does anyone know if the Brembo calipers from another bike (gsxr, etc) are compatible with the 610? I’ve replaced the seals on mine but they are leaking again. There’s no official rebuild kit with piston and the original piston didn’t look good after 4K miles. Other than trying to find another 610 caliper I’m wondering about another bike’s calipers.
the SM610 used axial mount calipers, while the later SMS630 used radials. You can get axial to radial adapters, and then you can use GSXR brembos if you get the 108mm bolt pattern or Ducati/Aprilia/Triumph/BMW Brembos if you get the 100mm bolt pattern. I suggest you get the 100mm bolt pattern as there are a lot more available for cheaper, if you're specifically looking for Brembos
