im taking my engine out of the frame of an 06 to replace the headgasket and misc other things. i have the workshop manual but couldnt find anything outlying the process to extract the engine from the frame. i was going to do the following: remove gas tank/drain carb; remove coolant; remove plastics; disconnect electronics; remove airbox/carb; remove exhaust; remove engine mounts; remove countershaft sprocket; remove shifter/rear brake; extract engine.
Am I missing anything else? What side does the engine remove from? if you've ever remove an engine from a husky any info helps.
