Well, I finally got me a motard.:
http://www.supermotojunkie.com/showthread.php?116719-Well-it-s-about-goddamn-time!!!
but when I finally got it home, I went to put down the stock kickstand, and found that instead of swinging out from the bike and stopping at say around 9 o'clock, it went right past, and will keep going until its almost completely swung in the opposite direction against the bike backwards (that make sense???)
I took a quick look with my flashlight in the dark, and it seems like its just loose hardware (there's an awful lot of shit holding on the damn kickstand) and I hope thats the case.
Just wondering if anyone has had a problem like this with that stuff coming loose, or if I've got an unusual problem here.
Thanks all.
Matt
Discussion Starter · #2 ·
Jesus, there's alot of pricey parts to this.:hmmm:
Uploaded with ImageShack.us# Number Name MSRP You Pay
22 50303023280 BUSHING WITH SCREW EXC USA $14.99 $14.99 BUY NOW!
23 50303023000 SIDE STAND L=377MM 98 $146.99 $146.99 BUY NOW!
24 50303023052 BOLT SIDE ST.SPRING M5 EXC98 $5.99 $5.99 BUY NOW!
25 50303023152 BOLT SIDE ST.SPRING M5 EGS98 $3.99 $3.99 BUY NOW!
26 50303026100 SIDE STAND BRACKET CPL. 2002 $42.99 $42.99 BUY NOW!
29 50303018000 RUBBER L=145MM $5.99 $5.99 BUY NOW!
30 50303024000 SIDESTAND SPRING 125-380EXC98 $5.99 $5.99 BUY NOW!
59 58429059000 Item No Longer Available $0.00 $0.00 BUY NOW!
60 6899785 Item No Longer Available $0.00 $0.00 BUY NOW!
86 54310086200 SELF LOCKING NUT M8 10.9 $1.99 $1.99 BUY NOW!
It appears as if #22 and #86, and possibly #24 are loose, hope they arent bent or stripped. Looked like everything else was there, Guess I'll find out in the daylight.
I have that problem too. The long stud on part 26 on mine bent. Causing the short stud (the piece that makes the kickstand stop where it's supposed to) miss the frame. So the kickstand just swings all the way around. I've been able to re-tighten the parts a few times and have the kickstand function properly but any more weight than just the bike on the kickstand causes it to swing around again. The frame mount on mine also get tweaked a bit when the kickstand swings around, so I have to straighten that too.
Hope that makes sense to you.
