My stock plug is drilled and wired.
Dot the plug with marker where you want the hole, take it out and place in a vise with small wooded blocks to protect the threads. Using a 1/16 bit, start the hole in the middle of one of the hex flats, then angle the bit and drill the hole into the hex recess.
