PowerFiend said:
I don't know about the CR500, but I have seen a 5.5" with a 170 Avon slick wedged into a CRF. It is very very tight, and you need to offset the countershaft sprocket and run a non-oring chain.
Hi, thank you for your answer...
My bike has the same swingarm of crf450 and so I can fit 5,50 rear rim.
I have to do many modifications but I think to know all what I have to do.....
I'd like to explain all the operations but my "english" is very rusty ...... :damn:
:headscrat
I have to:
1) assemble the rim moved to right
2) turn front chainwheel upside down (the front chainwheel's tickness must to be inside....)
3) put a 2,5 or 3,5mm (I don't remeber) thickness under rear chainwheel so the chain will be moved to left
4) modify chain guide and swingarm cutting a piece of chain guide mounts
5) mill rear brake's braket ..........
Ciao
