Hi,
Just picked up a set of 17" Behr KTM rims to go on my 2018 350 EXC and while the rear with the cush drive went straight in, front is proving less straightforward.
Front new rim appears to have bearings to suit a 20mm axle, which I assume makes it a pre 2003 wheel, whereas my 350 has a 22mm front axle.
Looks like it'd be possible to replace the existing bearings with 22mm units and run it straight off the 350 22mm axle and machine up some spacers to get it to sit right for the disc, but is there any existing drop in kit to do this or better suggestions?
Many thanks!
Many thanks!
