1 - 20 of 47 Posts
So summer has arrived,and i thought it would be a good idea to install my sm wheels onto my 2012 ktm 350 exc.
Before
2011 350 sx-f Graphics/ Plastics and decals where used off-road.
So Far Parts Ordered.....
Full White Plastics Kit - MX1 Australia (Acerbis Retailer)
2012 "White Chrome Graphics" From Ktm PowerParts
Orange Frame Protectors - Ktm PowerParts
Smr Fork Guards Black in stock --- White on backorder in Austria Still Pending
White Sm Fender From Ktm PowerParts
Husaberg FS570 stand - Husaberg Spare Parts
2011 350 sx-f fuel tank complete with fuel pump - EBAY
Male Fuel Quick Release Connector -Ktm Spares
EFI Fuel Safe Hose Clamps - EBAY
Small Mirrors - EBAY
320mm Relocator- Ktm PowerParts
DNA 17" wheels
If you need any part numbers feel free to ask.
While those parts took there time to arrive, i started dismantling the bike.
Front Fender Off And Head Light Mask.
-Force radiator guards anodized orange, look good and protect the radiators well.
Radiator Shroud and seat off.
Both Air Box Covers Removed
More to Come...
Ok onto the wheels installation
Front wheel installed, With 320mm Relocator and black fork gaurds
Rear Wheel Installed,Chain(non o-ring) And Husaberg FS 570 smaller kick stand installed
I've gone for a 13t, 44t set up, Shall be interesting to see how the motor goes
Kick Stand Comparison
Original kick stand top
Husaberg Stand Bottom
Discussion Starter · #7 · (Edited)
Reassembling the Bike
Rear Fender, Airbox and a clean airfilter installed.
Airbox Covers
Radiator Shrouds And Tank
Sm Front Fender and HeadLight Mask
FINISHED :D
More To Come, Black sx-f tank will be install soon.
Discussion Starter · #16 · (Edited)
SX-F black tank
So the tank has arrived and a few parts to make it fit to the exc.
The Tank.
The sx tank stock has reverse fuel connectors, i ordered a male connector for the tank so i wouldnt have to mess with the hose on the throttle body.
The tank with a new fuel connector
So now the fuel tank can connect, i've used tape over the EFI safe hoseclamps.
More Problems to come.....
Discussion Starter · #17 ·
Next Problem...
If you have a thermo fan installed this will have to be removed.
Next Issue
Electrical Connections dont match up for the fuel pump
Heres, the stock 3 pin exc clear tank connections
2 pins for power and 1 pin for low fuel
This is the sx black tank 2 pin connector
Pretty Simple, just need an adapter....
Did a bit of research and found out that ktm use "AMP superseal connectors"
Ordered a 3 pin female, and a 2 pin male connector
curious as to what the third wire/fuel line does. the SXF only has 2 wires and fuel lines attached to the pump, the EXC has a 3 wire connecter and 3 lines. one feed and one return makes sense, but the third one...
btw, did the sxf tank come with a complete fuel pump assembly? and if yes, wouldn't it have been possible to swap over fuel pumps and base plates to solve the connecter issue with the parts at hand?
Discussion Starter · #19 · (Edited)
Fuel connections
Know i ordered the tank i looked at theses 2 photos from the 350 sx-f and 350 exc spare parts book
350 sx-f
350 exc
the fuel pump has different connections on both tanks, and if you look at the exc connection point, there is no fuel hose connection. The sx-f tank has 2 connections the power and hose at the back of the tank. The exc fuel hose exits the tank at the bottum of the tank.
So back to your original question , I bought a 2011 250 sx-f fuel tank, compete with fuel pump .If you purchase all the parts from Ktm it will cost around about 700$ Australian dollars, I manged to get the tank complete brand new for $350 AUD
shipped. And no you can't transfer the fuel pump over.
Discussion Starter · #20 ·
The 3rd wire is like a switch it gets a positive from the pump and when the level gets to low the switch closes and the 3 pin gets 12v which powers the low fuel light.
1 - 20 of 47 Posts
