Just picked up an 08 sm 610. Noticed that the taillight always is fully illuminated as if the brakes were being applied. I noticed that the two plugs on the switch on the frt brake lever felt a little loose and when I unplugged them the taillight went back to running light and not full brightness. any tips on where to look? thanks
Standard troubleshooting is to divide the thing in two & see which side works or not.
Could your front brake switch bad? Continuity check on the switch. Or just badly adjusted.
Try shorting out the wires on the harness side of the connector.
It is always those gay electrons, blowing fuses that cause problems;)
thanks for the help.... ended up being the connectors on the front brake sensor were loose. just gotta put new connectors on and should be good to go
