1 - 18 of 18 Posts
Hi I am parting out a motor from my drz400sm. I am parting it because SOme bearings need to be replaced and it needs a new oil pump. I didn't want to pay 900 in labor fees so i bought a new motor and installed it.
Still Have the passenger pegs!
SOLD STATOR COVER, CYLINDER HEAD
Everything is for sale except for the oil pump
Crank Cases $150 (Just cases with some bearings few broke)
Left side 75
Right side 75 I was told there is a little mark on the cases that is from a piece of metal. It shouldn’t effect anything. I can take close up pictures its tiny. Can be fixed with JB Weld
Will sell as a pair as well.
Transmission Gears and counter shaft $200
Shift lever $30
Will sell transmission complete
Crank shaft (little wear on the con rod) $50
Cylinder 100
Piston $50
Cylinder head cover $25
Clutch Basket $65
Clutch plates with springs $40
Starter $40
Starter relay $10
Starter Gears $35
Inner Clutch cover $50
Engine cover $75
Stock SM Cams (set) $100
Cam chain $15
ACCT $15
Flywheel $70
If I didn’t list something you want its probably because I forgot it. I have all the parts except a good oil pump.
You can text me at 920-268-5834 or message me on here. I have pictures of every part
Thanks for looking
Hey - how much were you looking for for the complete transmission? Or, would you consider selling the counter shaft alone (if so, how much)? Also, what color is the headlight? Thanks!
Discussion Starter #9
I would like to sell the transmission complete but for the right offer i might be able to sell just the counter shaft. The head light is Black
Discussion Starter #12
Seems like you've changed the headlight wiring and it's missing wires... I've PM'd you but haven't heard back!
Opps i am sorry! My fault didnt see you pm'd me, i actually bought the bike with the headlight on it and that how the previous owner had it.. But i can help you wire it up ill shoot you a pm!
Seriously?
Are some of you lacking the reading comprehension to understand what the OP meant by "motor part out"? OP is parting out the motor, that doesn't mean the wheels, plastics or pegs are for sale. Never mind that the thread was over a year old when it was brought back.
Idiots.
edit: Forgot a word.
It says right in the post that he still has the passenger pegs, or could you read that?
idiot...:headshake
1 - 18 of 18 Posts
