1 - 8 of 8 Posts
2007 CR85 Supermini - $1850
2007 CR85 Supermini
-85cc w/port work, and high comp piston
- 7-8 hours on the top end
-High capacity alum radiator
-aftermarket pipe w/2 silencers
-CRF450 front brake setup
-17" wheels with GP125 slicks
-spare plastics and motor parts
Starts right up and runs great, jetting is spot on. My first two stroke but this is a fast bike for a stock bore. Up for sale as its not getting properly worked out at track days as often as I would like
Can be easily delivered anywhere in the northern Delaware to central PA area
$1850
text 302-420-1799 for more details or questions
List Date: 8/10/2014
For more info, click here to view the original listing: 2007 CR85 Supermini - $1850
This item is no longer available.
Mobile friendly version: 2007 CR85 Supermini - $1850
Go Mobile: Download the free Panjo iOS app now!
Sorry, haven't been on in a little while.
She's still for sale. PM for details
Right now the bottom and and top end have just been redone, along with the clutch. Zero hours, just heat cycled and run around the block
Bump.
Ok, went through the motor and clutch this winter and everything is fresh.
-New piston/rings
-crank and rod.
-Bearings
-Replaced the pressure plate with a used good condition one, old one was scored.
Probably a few other odds and ends I'm forgeting. The bike has only been heat cycled 6-7 times and run up and down the street once.
So it's honestly less then 1 hour on the motor. Starts on the 1st or 2nd kick, idles great, and runs strong.
I'm selling as I never ride it. Shoot me some offers.
1 - 8 of 8 Posts
