Hey Supermoto world!
Recently acquired a 2005 KTM 450 SMR, using it at Kart Tracks in SoCal. In the process of making it more reliable, easier to work with, and part of that is installing a radiator fan.
I found this kit here, and it looks very similar to the fans used on ebay that fit the SMR here, but comes with the temp plug and wiring needed to install. Wondering if this would fit the SMR, I know the EXC is more trail oriented, but I believe it's for the most part the same engine and wiring wise.
Wondering if there's any kits people would suggest, and/or any methods or suggestions for wiring up a temperature activated fan.
Thanks!
Check out Trail Tech and also Spal Fans. Trail Tech has universal kits with a digital adjustable temp setting. Spal has really good fans and they move more air than most. You'd pick the Spal by the biggest diametr that would fit in there. Trail Tech also has individual in line temp sensors as well.
