1 - 14 of 14 Posts
List of parts availble:
450EXC motor w/ e-start(will include battery and all pertinent wiring to the e-start) - can include Rekluse auto clutch or without - $1450 w/e-start(no Rekluse) or $1750 w/e-start & Rekluse
I may part the motor, if I do these would be the prices - PM w/ interest on parts -may get me to part motor rather than selling as whole. I will keep PM of interested parts and let you know if I decide to part the motor
Head - $275
EXC 6-speed transmission - complete w/ shift forks and drum - $350
Rekluse auto clutch - approx. 20 hours - works perfectly - $300
E-start system - complete with wiring and battery box - $350
EXC stator/flywheel/pickup/cover - $150
Crank & balancer - $175
Cylinder - $125
Piston w/ wrist pin and rings - $60
Cam - $90
Cases - $150
Cylinder studs - set of 4 - $20
Frame - $250
Front wheel 21" excel w/ tire/tube/rimlock - $240
Rear wheel 18" excel w/ tire/tube/rimlocks - $270
Forks 48mm (I have two sets - one EXC, one SX) - $375
Fork protectors - pair - $15
Shock - $225
Shock spring - 88/250(white) - $70
Front brake assy - complete w/ pads - $100
Rear brake assy - complete w/ pads - $80
Headlight - $70
Front fender - $15
KTM computer w/ wheel pickup and handlebar push pad and light switch - $75
39mm FCR w/ PowerNOW - $350
Rekluse Left hand Dual brake setup -- like new -- $350
Rekluse e-axle -- like new -- $135
Scotts Submount Damper setup -- essentially new(mount is all) -- $360
Header - $75
EXC US forest service approve spark arrestor - $100
Front axle - $20
Rear axle - $20
Swingarm - $90
Footpegs - pair - $30
Rear brake pedal - $40
Shifter - $15
Clutch slave cylinder - $45
Skid plate - $20
Triple clamps - 48mm - $45
Front disc - $65
Rear disc - $65
Chain guide - $20
Swing arm pivot axle - $15
there's more I will add to the list on a later post - but you can always ask((I most likely have it)
Thanks
Chris
PM sent
EXC 6-speed - SOLD
EXC stator/flywheel/pickup/cover - SOLD
Frame - SOLD
Front wheel - SOLD
Shock spring - 88/250(white) - SOLD
Headlight - SOLD
Front fender - SOLD
KTM computer - SOLD
39mm FCR w/ PowerNOW - SOLD
Scotts Damper setup - SOLD
EXC US forest service approve spark arrestor - SOLD
Front axle - SOLD
Triple clamps - 48mm - SOLD
Updated list of item as of 3/4 noon
SM catch can KTM stock can - $30
Kickstand complete w/mounting hardware - $70
41mm FCR - $325
Billet KTM Triple clamps - 48mm - SX style 18-20mm adjustables - $150
Head - $275
Hybrid transmission - close ratio 1-5 w/ wide ratio 6 - complete w/ shift forks and drum - $350
Rekluse auto clutch - works perfectly - $300 - sold(payment pending)
E-start system - /battery box/battery - $350 -sold(payment pending)
72mm stroke Crank & balancer - (525 or 450exc/mxc) - $175
89mm Cylinder - $125
89mm Piston w/ wrist pin and rings - $60
"55" Cam - $70
04 Engine cases - $150
Cylinder studs(for 72mm stroke cylinders) - set of 4 - $20
Rear wheel 18" - $270 - sold(payment pending)
Forks 48mm (I have two sets - one EXC, one SX) - $375set
04 EXC Shock - $225
Rear axle - $20
Swingarm - $90
Shifter - $15
Complete clutch assembly - Master cyl/braided line/slave cylider - $150
Skid plate - $20 -- sold(payment pending)
Front disc - $65
Rear disc - $65
Chain guide - $20
EE exhaut pipe protector - $20
Take off Rental bars(like new) - $35
Radiators(pair) - SX style w/ hose set - $240pair or $120ea
Thanks
Chris
Hybrid transmission - SOLD
41mm FCR - $325
Head - $275
"55" Cam - $70
04 EXC Shock - $225
Rear axle - $20
Swingarm - $90
Shifter - $15
Front disc - $65
Rear disc - $65
Chain guide - $20
Thanks
Chris
Discussion Starter #6
Kickstand -- SOLD
41mm FCR - SOLD
Billet KTM Triple clamps - SOLD
Rear wheel 18" - SOLD
04 EXC Shock - SOLD
Skid plate - SOLD
Rear brake pedal - SOLD
Rear disc - SOLD
EE exhaut pipe protector - SOLD
Chain guide - SOLD
Rekluse auto clutch - SOLD
E-start system - SOLD
Updated list of item as of 4/7
Rekluse Left hand Dual brake setup -- like new -- $300
Rekluse e-axle -- like new -- $125
Head - $275
"55" Cam - $70
Forks 48mm EXC - $375pair
Swingarm - $90
Shifter - $15
Front disc - $65
Radiator(left side) - SX style - $120
Rear axle - $20
Thanks
Chris
Discussion Starter #7
Take off Rental bars(like new) - SOLD
Updated list of item as of 4/8
Head - $275
"55" Cam - $70
Swingarm - $90
Shifter - $15
Front disc - $65
Rear axle - $20
Thanks
Chris
Chris,
I have a 2004 KTM 450 SX.
I have already converted the bike to a six speed. It does 100 MPH, its great.
I am tying to get the bike steet leagal and am interested in the following parts;
EXC stator/flywheel/pickup/cover - $150 (I am assuming that is a 100 watt stator)
Also,
How much for the rear sub frame?
Is the skid plate aluminum?
If you could send pics of all the parts I requested that would be awesome.
Please send everything to [email protected]
I will wait your reply
Thank you,
Jesse Santi
Head - $275
Cylinder - $125
Cam - $90
Cases - $150
Frame - $250
Shock - $225
Headlight - $70
Front fender - $15
Header - $75
Front axle - $20
Rear axle - $20
Swingarm - $90
Shifter - $15
Skid plate - $20
Front disc - $65
Rear disc - $65
Chain guide - $20
Thanks
Chris
Discussion Starter #10
Updated list 4/20
*bike had 68 hours - great parts if you need them
Rear axle - $20
Swingarm - $75
Footpegs - pair - $25
Shifter - $10
Shipping not included
frame
I need the frame for a 04 exc 525. Im pretty sure there are the same. Has your frame been street titled and where, and is there any damage. Do you have any pics. Thanks john email at- [email protected] thanks
1 - 14 of 14 Posts
