I'm setting up my 01 EXC for SM. I'd prefer the 4.25"-4.50" rear, but if the 5" will fit then I'd go for it. I'll also need a large front disc and bracket for the caliper. I have a set of 21 and 19's with Excels that fit a Husaberg with discs and sprocket for cheap if anyone is interested.
Thanks,
Brian
503-631-3291
[email protected]
Dont forget you need the 20mm axle up front. I have a 625 lc4 with the 17's. It has the older front forks and axle.
biff10,
Doh! I didn't quite understand your post. Your right, I do have the 20mm axle. Do you know what size the newer bikes have?
