These wheels are off an early 2000's Derbi GPR 50 wheels, rotors tires. My plan was to use them for a mini-gp conversion.
These are 16” wheels. As you can see in the pictures I bought them for a conversion project on a CR85. They fit pretty decent right out of the box, but it was going to take custom spacers to get them on. The bearings in the wheels are the same as the rear axle of the CR85. The 16” size let the rear wheel fit with a little bit of clearance to allow chain adjustment.
I recently acquired a bike all set up for mini, so this project is up for sale. The CR85 in the pictures is also for sale.
The wheels are dead straight and in great condition…there are a couple marks from tire changes but otherwise the rims are mint. The rotors are also flat and smooth with little wear. The front rotor is 260mm. The rear rotor is 220mm. The sprocket is a 420 size chain, 42 teeth. I have identified the mounting pattern with AFAM, and other sizes are available as well as offsets to help with your application.
The tires are practically new Michelin A39/M39…still have the nipples on them. Sizes are 90/90/16 front and 120/80/16 rear. Before I bought these I found that much of the good rubber available in 12’s is available as 16’s. The size of the front rotor and being tubeless was a bonus for what the set cost me. I am half tempted to keep them for a future project cause they are so neat.
I’ll ship them anywhere in the 48 states for $350 just as you see them. Trust that I will pack them carefully to ensure they are still round when you get them. Pick up for $300, located in Greenville, WI. I will likely be able to overlap at Road America or Shawano/US Air. I can probably have arrangements for them to get to Sugar River.
I'm subscribed to the thread or you can PM or email direct at [email protected].
