08 SM610 shorty levers
4282 Views 6 Replies 5 Participants Last post by  Markenzi Pg
Looking for some shorty levers for my 08 SM610. anyone know of anyone out there who makes them or where to buy? I HATE the ridiculously long stock ones and I want the two finger levers. Thanks!
Check the parts listing to see if the 610 has the same levers as the 450/510 - if so I have part numbers for you.
You are in luck. Midwest Mountain Engineering makes a sick shorty clutch lever and one week ago released a matching brake lever. It is actually a two finger lever not just a short lever. It is supposed to reduce the clutch pull by half. Works on the Magura and Brembo setups. The only drawback is you have to disable the neutral switch that requires you to pull in the clutch to start the bike. There is a thread on cafehusky.com about how to do it. It literally takes 5 minutes.
Isn't the 08 still a cable driven clutch?
I'd love to have something like that for my 06 sm 610.
Yeah I checked out those levers but it doesn't look like they will fit. the brake looks different from the stock one and the clutch on the 08 is a cable clutch... anything else out there??
These threads might help you:
http://www.thumpertalk.com/forum/archive/index.php/t-668453.html
http://www.supermotojunkie.com/showthread.php?34509-Asv-Front-Brake-Lever&p=311246#post311246
