Just traded for this bike from my nephew. He’s done quite a bit trying to solve an issue with it. Intermittent spark I guess if you could call it that is the issue. It’s there then fades to nothing after a few kicks. He replaced almost everything in the ignition but not sure about the stator or pulser coil. I’ll find that out. What he hasn’t done is check or replace wiring harness. Has anyone seen this before? Also, they don’t make the stock wiring harness anymore, can a different models harness be used? It does have lights but no battery setup. Haven’t got to really check into yet as the bike is half way across the country until later this month but wanted to get a head start.
