I have my 07 510 SMR parted out and ready for sale.
I bought the bike from a user here back in 07 where it's life began at Loudon NH.
I took it to Deals Gap 3 times, all over the New England back roads, rode it over the Continental divide on Loveland pass and the canyons out here in So.Cal. This bike has seen plenty and given me more fun than any other bike, but that time was always on a timer and I knew it.. around the 225 hr mark The countershaft bearing inside the motor threw it's retainer cage and needs to be replaced. Pictures of motor below. That was my signal our time was over so she goes the way of parts so others can keep enjoying her.
Everything is pictured.. if you see a pic it's still available. As the item sells it will be replaced by a SOLD picture. That's the easy way to adjust the post once the editing period is over.
The bike is stock except for a few key bits: Triples, damper, vortex widebars, JD jetting, catch can, rad covers, heal exhaust guard and some race plastics.
Here she is just a few months ago atop Palomar Mtn.
On with the part out..
ALL SALES ARE FINAL!! NO RETURNS!! NO TRADES!!
PARTS WILL FIT MOST YEARS, IT'S UP TO YOU TO DETERMINE IF IT FITS YOUR BIKE, NOT ME.
SHIPPING IS DONE VIA USPS PRIORITY BOX. IF IT FITS IT SHIPS FOR $10.95 or $14.95
OTHERWISWE IT GOES UPS FROM 92131 ZIP CODE
ALL UPS SHIPPING STARTS @ $12.50 AND INCREASES $.75 PER POUND
I'VE INCLUDED WEIGHTS OF THE ITEMS SO YOU CAN ESTIMATE THE SHIPPING. I'M TO BUSY TO RUN BACK AND FORTH TO WEIGH PACKAGES SO USE YOUR HEAD AND ESTIMATE THE SHIPPING. IF YOU'RE SHORT I'LL BILL YOU, OVER I'LL REFUND.
ALL PAYMENTS GO THROUGH PAYPAL, PLEASE MAKE SURE YOUR SHIPPING ADDRESS IS INCLUDED
BEST OFFERS, SEND PM AND IF I LIKE IT WILL REPLY WITH PAYPAL LINK.
First up is the GOLD of this part out, the Zero-offset triple clamps paired with a GPR damper w/Vortex widebar package.
The Triple was made by Tri-Star and GMD Computrack out of Boston. You can contact GMD and ask for Peter Kates and he'll tell you all about them. These are very rare and can no longer be made. They make a substantial difference in your turning and stability. If you race, these are a must have.
$1200 for the combo $1000 for the Triples $375 for the Damper/bars to break the set Ship = 20lbs - 10 lbs - 10 lbs
Computer - $175 - ship= $14.95
No idea how many miles, I always left it on trip miles to know when to add fuel (this is a warranty, the original computer got wet and shorted out, they sent this one 8 months later so bike was run for 6 months w/out computer
Handle Bar Switches Left and Right $25 ship = $14.95
Stock mirrors in a box - $35 - Ship = $14.95
Vortex oversize supercorss bar - $50 - ship = 6 lbs
Front Brake assembley - $100 - Ship = $14.95
Rear brake assembley - $100 - Ship = $14.95
Clutch assembly (has slight leak at lever piston) - $75 - ship = $14.95
Throttle assembley - $35 - ship = $14.95
Cycra Pro Bends w/triple mounting hardware - extra bits and pieces - $75 - ship= 8 lbs
These have been crashed 6 times.. slightly bent but bolt right up.
Stock Fork tubes - $350 - Ship = 50 lbs (oversize)
Rear Shock w/stock spring - $175 - Ship = 25 lbs
Stock Triples - $75 - Ship = 10 lbs
Stock bars and clamp - $45 - Ship 8 lbs
Gas Tank - $150 - Ship 12 lbs
Seat - $50 - ship 8 lbs
Complete race plastics- have scratches and frankenstein zip ties on left tank shroud
- $150 - Ship- 30 lbs (oversize or 2 boxes)
Rooster Heel exhaust guard - $20 - Ship = $10.95
Horn - $25 - Ship - $10.95
Kickstand - no bolts, they fell off - $35 - Ship = 5lbs
Radiators and hoses - $100 - Ship = 10 lbs
Airbox - $35 - Ship = 8 lbs
Rooster Radiator guards for rads - $40 - Ship = $14.95
Gear Shifter - $15 - Ship = $10.95
Stock BENT exhaust (bent mid pipe and can after last crash, don't line up right but works) - $65 - Ship = 30 lbs
Stock GOOD exhaust (bought to replace bent parts above) -$100 - Ship = 30 lbs
Stock Street rear fender w/emission info and plate holder (need this sticker to reg bike) - $50 - Ship = 15lbs (oversize)
Stock Wheel set - $750 - Ship = 50lbs - mild scratches as i do my own tire changes.
comes with rotors and sprocket(42T Renthal) Front tire will be removed, rear tire is brand new (less than 100 miles) BT003 street.
Spare Rear wheel - $250 - Ship = $12.50 + $50
Wiring and electircal - $15 - $75 - Ship = $8.95 - $14.95
Swing Arm - $350 - Ship = 40 lbs (dirty in pic, will be cleaned before ship)
Frame - $500 (comes with CA title) - ship = 75 lbs
Subframe - $285 - Ship - 20lbs (oversize)
Motor - $575 AS IS (needs new counter shaft bearing - Ship = QUOTE!
Motor comes whole with starter, mag, clutch and all covers.
OK I think that's it.. any questions please ask and if it's not pictured, it's been sold.
