So I had this problem for a while now I found out what was happening last night and I fixed it road it to the gas station this morning road and sounded great get home let it sit for a couple of hours go to ride it and it stared happening again it seems like the bowl is over filling but if you hold the bike up right it sits below the level line because I adjusted the float to stop it there what I can do it drain the bowl to about half full and cut off the gas and it starts no problem idles fine as soon as I turn the gas on it immediately floods the engine and won’t start until I get rid of all the gas out of the cylinder and empty the bowl half way not sure what is causing this to happen I’ve also just took of the carb inspected the float needle clean and I cleaned it anyway and cleaned where the float needle goes then I adjusted the float more so less gas goes to the bowl still having the same problem here is a video of what is happening drz problems - Google Drive
