1 - 13 of 13 Posts
I just bought my first SM about a month ago. The guy who owned it before me changed the sprockets to 16Front 47Rear. Ive done a 3x3 mod and rejetted with the JD jet kit, Blue needle 3rd clip, 155 Main jet, 25 Pilot jet, air screw 2.5 turns out. The mods i made gave it more throttle responce and it pulls harder and way smoother after the mods.
It seems like i have to work pretty hard to do wheelies with the sprocket setup it has on it now. I can roll on 1st pretty hard and get it up, but in 2nd I have to work extremely hard to get it up, I can clutch it pretty hard and still only get the wheel up about 1-2 feet.
For the record im not a wheelie expert by any means but my 2002 YZ250F dirt bike is hella easy to wheelie and maybe the difference in bikes is a hard transition to me. My Drz cruises at reasonable RPMS at 60-65 I really dont wanna kill my cruising speed but i want to be able to wheelie a little easyer.
So with that said should I do a sprocket change or am i just weak and need to keep practicing.?
any help is appreciated..i have the stock sprockets BTW..
thanks
Drop Front sprocket back to 15 or go to a 14. Bike will come up easy then... Downfall, you will loose some top end with a change to 15 and more with 14. FYI 15/41 is stock.
i really like the 60-65mph rpms the way it is..if i changed to a 15 front you think 55-60mph rpms would feel like they do now at 60-65.?
It would drop your cruising speed about 5mph. I ran 15/43 and wished I went with 14/41,43 but I live in the Mtns of Western Northcarolina. I liked the lower gear,to help under powered bike get out of corners. If you have the 15 just swap it out..... Doesnt take long and will fit chain.
awsome thanks for the help bro....once my impact gun battery charges ill get er done n post back later tonight..!
i use 15 or 16 on the front and use a 39 on the rear , this way you can change the gears and use the same chain , i use the 16/39 for street and big tracks , the 15/39 i use only for go cart tracks , i do have a 470cc motor ,
i have run stock 15/41 then tried 15/39 then 16/39, overall for me 15/39 works the best
I'm pretty happy with 14/44, but there's no highway here.
When i got the bike it had 16/47 I liked the gearing and cruising rpms but I had to try to hard to wheelie..
I changed it to 15/47 which makes it super easy to wheelie but the cruising rpms are a little high.
I'm going to get a 46 tooth rear sprocket and use the 15 front. That gear ratio is right in the middle of the 2 I've used so far. Hopefully I'll get the happy medium between the 2
i have 16/39 on right now and i can bring it up easy in 2nd with a blip of the clutch . and 15/39 i wheelie at the track a lot fun times
A rule of thumb is,for every one tooth dropped on the front, is like going up 3 teeth in the rear. With that theory, is 15/44 more what you are looking for?
Discussion Starter · #13 ·
15/44 is the same gear ratio as 16/47 = 2.93
and if i go 15/44 im probably gonna need to take a link out of my chain, which im trying to avoid
1 - 13 of 13 Posts
