The 86' CR 80 trees are a bolt on- with swapping out the bearing to XR 100 style or pick up a XR/CRF/50/70 tapper conversion kit. All the 33mm CR 80 forks legs will interchange 86-95'- also, Front wheels and front brakes 86'-07'
I'v seen custom stems aviabable for the 96'-07' CR 85 fork. Through ProCycle in NY. likly have more into the fork conversion than the bike LOL
As for the Swing arm, I have KX85,CRF150R,CR85 and KX65 in my parts inventory. The KX 85 look very doable with some machining. The KX65 is a bolt on in regards to the pivot area. Over all length (for 14/16" wheels) and sprocket offset are the down falls of the KX65 swing'r. Would be perfect to run 12's.
I heard the old style CR 80 swingarms are close? Have yet to confirm this my self....
~G
FS MINT 04' CR250R Enigne Complete
