Results 1 to 3 of 3
Thread: Question on brake relocator for crf450
    Nov 2005
    Gainesville, Fl
    281
    Default Question on brake relocator for crf450
    So I have all my parts, except for my wheels - which should show up in a week.
    I'm sitting here looking at the motomaster brake relocator I bought from motostrano outlet (for a smokin deal I might add) and I'm just perplexed. It only has 3 tapped holes while the last hole isn't tapped. I just find that odd. But everything I read about the adapter shows it to be the right one - part # 211010
    Is it just going to all make sense when I put everything together or what? Someone tell me I'm not crazy
    Edit: I would have posted in the Honda section, but it doesn't seem to see much action unless you're riding an XR650
    ______________________________________________
    2008 CRF450X-SM
    2003 DRZ 400S-SM (might be for sale soon)
    2001 TL 1000R (buy me)
    Oct 2008
    Orlando, FL
    576
    Its because it is a floating caliper, you will see that it has two pins one that threads in the caliper and one that threads in the bracket that way it is free to move back and forth once mounted, it will make sense when you pull the other one off, be sure to pack them full of grease and you'll be good to go!
    If you can't get it done with 40 hp you shouldn't try it.
    Nov 2005
    Gainesville, Fl
    281
    Thanks man, I appreciate it.
    2008 CRF450X-SM
