Help on wiring / turn signals on 2003 WR450 PICS INSIDE
Results 1 to 6 of 6
Thread: Help on wiring / turn signals on 2003 WR450 PICS INSIDE
  1. #1
    Join Date
    Sep 2008
    Posts
    33
    Default Help on wiring / turn signals on 2003 WR450 PICS INSIDE
    Hey guys. Just purchased an 03 450 Supermoto and looking to put a set of turn signals on it. Rear brake light works sometimes. Think it needs a new sensor. Might be a baja designs kit? I think I may be missing a relay for the turn signals and the horn. Looking for any type of help I can on how to wire turn signals into this and what I actually have. I have the Zeta handguards I am looking to use as turn signals. Thanks a lot.
  2.
    Advertisement
  3. #2
    Join Date
    Apr 2009
    Location
    Knoxville, TN
    Posts
    144
    Default
    somebody help the guy out......
    '06 Chevy Cobalt SS-Supercharged
    '05 Husky SM510R "Plated"
    '87 Husky WR 430 2-Stroke Dirt
    '05 Bombardier Outlander 400
    '05 Honda Rancher 350 & Recon 250
  4. #3
    Join Date
    Jan 2009
    Location
    Columbus, Indiana
    Posts
    48
    Default
    looks like a cluster fuck, you may be better off making a new harness instead of troubleshooting that one
    06 DRZ400SM
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Jan 2009
    Location
    Michigan
    Posts
    534
    Default
    Need to know the acc switch your using and color codes for it.
    97 rm250
    01 680r
  7. #5
    Join Date
    Jul 2008
    Location
    Saskatoon, SK. Canada
    Posts
    162
    Default
    ...get out your DMM and start tracing wires and get some masking tape or something and mark the wires or else write it down on paper.
    2007 Husaberg FS650e
  8. #6
    Join Date
    Oct 2008
    Posts
    58
    Default
    The harnes looks completly butched up. Get a new harness from Carl at Pro Cycle. all those wire taps are bad news. Start fresh and solder everything correctly. Get weatherproof connectors for the rear so you can remove the rear fender if necesary. My setup is bulletproof on my YZ450F.
    Automotive and Cycle Inspection Mechanic. Broomall Pa.
  9.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
