DRZ400SM Oil Change
Results 1 to 18 of 18
Thread: DRZ400SM Oil Change
  1. #1
    Join Date
    May 2009
    Posts
    2
    Default DRZ400SM Oil Change
    Just bought a 07 DRZ 400SM. Love the bike but it did not come with owner's manual. What kind of oil do you use and how much oil do I fill it with. ( both tranny and case). Thanks
  2.
    Advertisement
  3. #2
    Join Date
    Apr 2009
    Posts
    80
    Default
    http://www.sixfivepony.com/drz400/ it says its for the S model. but it might be the same... anyone know for sure..
  4. #3
    Join Date
    Oct 2006
    Location
    New Oxford, PA
    Posts
    2,228
    Default
    undo the drain plug....roll the bike away...roll a new bike in its place and re-insert the drain plug......
    sorry, its late and Im tired......
    07 SXV 550
    Search "Oreodoodles" on YouTube for my videos
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    May 2006
    Location
    Sacramento, Ca
    Posts
    31
    Default
    Do a quick search, this has been hashed over to death with no final solution. The prior link will provide an overview of the process. The engine and tranny share their oil so whatever you choose is lubricating both parts. I have tried many of the reccomended choices so far and I prefer Yamalube gold 15w-50, although I am not sure if it is worth the $30 investment in oil yet.
  7. #5
    Join Date
    Jul 2008
    Location
    Hopkins, South Carolina, United States
    Posts
    496
    Default
    oil change can be confusing on the SM at first. Drain your plug on the bottom of your motor. Next look on your frame, right below the exhaust where the frame is pretty much welded together, there is another drain plug there. Unscrew that one and let the oil drain out of the frame. If you want to do the filter, it is on the right side of the bike with 3 screws holding a cap on. that is where the filter is. Replace and screw back on. Replace all drain plugs!!! My bike took right at 2 quarts once everything was said and done.
    On the frame by the steering colmn there is the oil (dip stick and add in) pour in about a quart and start the bike, let it run for a min or two, and add some more. you should be able to check the oil with the dip stick once you get in around 2 quarts. That should do it. good luck!! I haven't done the tranny oil yet. Oil brand, that is up to you. I think i put in 15w-50. everyone has their favorite brand...
    2006 GSX-R1000 / 2007 CRF50F / 2008 DRZ 400SM
  8. #6
    Join Date
    Mar 2008
    Location
    Guelph Ont Canada
    Posts
    103
    Default
    Basic Oil Change walk through for your DR-Z
    http://www.thumpertalk.com/forum/sho...d.php?t=665513
    And don't forget the O-ring behind the oil filter!
    White 2008 DR-Z400sm, FCR39 MX, MRD/SSW, Big Bore, Hot Cams, K&N, DONE....... I think .
  9. #7
    Join Date
    May 2008
    Location
    greensburg, in
    Posts
    2,068
    Default
    Drain crankcase and frame and filter. There is a drain plug at the filter area too so you dont run oil all down the casing. Some have said to clean the oil screen as well but I have not done that one yet.
    Drain the oil then stock fill amount is 1700ml. Converted it is 1.79 quarts (1.8) quarts.
    The frame screen is also near the frame plug that hase a rubber hose connecting to a steel elbow. There is a screen in there somewhere that catches the crud much like the filter.
    2001 Suzuki TL1000R
    2008 Suzuki DRZ400SM
  10. #8
    Join Date
    Oct 2008
    Location
    Laurel, Md
    Posts
    5,345
    Default
    1.8 quarts is recommended....I use Spectro gold semi-synthetic 10w-50
    2007 CRF150R winter project
    2001 XR 50 (Wicked cool),
  11. #9
    Join Date
    Mar 2009
    Posts
    45
    Default
    If the o-ring is missing, you can pick up a pack of 10 at almost any hardware store for the same price that the dealer will charge you for one.
  12. #10
    Join Date
    May 2009
    Posts
    2
    Default
    Thanks for the Info guys. How many miles do ya'll go before an oil change?
  13. #11
    Join Date
    Mar 2009
    Posts
    45
    Default
    Depends on what kind of riding I am doing. I do some offroad riding and push the bike a bit on back roads and usually change at around 500 miles. If doing any time on the track, I usually change it after every ride. If you're just comuting and riding around town, I would recomend 1000 miles. Just my two cents.
  14. #12
    Join Date
    Oct 2008
    Location
    Laurel, Md
    Posts
    5,345
    Default
    1000-1500 between changes
  15. #13
    Join Date
    May 2009
    Posts
    53
    Default
    ive read people waiting 2000 miles plus but i have back roads and some highway i stick right at 1000 if not less it doesnt cost much and it doesnt hurt to change it =)
  16. #14
    Join Date
    Sep 2007
    Posts
    58
    Default
    the manual says to use 10w-40 and to change it every 3500 miles. I used semi synthetic 15w-50 in the summer while I was in AZ (constant 100+ degrees) and now that I'm in UT I use s.s. 10w-40.
    I change the oil every 3K miles. While I do ride it hard, I dont offroad it much. Also, I end up topping it off after every couple rides. With that said, I think a lot of people change their oil too frequently.
    [SIGPIC][/SIGPIC]06 Suzuki DRZ400SM: Yellow, Yoshi, 3x3, jetted
    05 Toyota Tacoma TRD Sport, murdered out (black on black): 3" Rev Tech, 285s on 18" American Racing Teflon Mojaves, AFM intake, Gibson exhaust
    07 Suzuki LTR 450: White, Two Bros., cherry bomb
  17. #15
    Join Date
    Dec 2014
    Posts
    1
    Default Crash Washer
    Good evening Sirs, I kjust made a search and this thread posp out as i am searching for what king of oil i will used for my DRZ, how about the crash washer mentioned from here how does it looks like on a larger picture and its exact size, where could possibly get that one? I am from asia and very limited supply I think we have here... thanks
  18. #16
    Join Date
    Jul 2013
    Posts
    178
    Default
    Quote Originally Posted by dadsbigbike View Post
    There are 2 crush washers used on the DRZ one for the frame drain (10mm) and one for the crankcase drain (12mm), you can use aluminum or copper sealing washers in their place if needed.
    2007 DR-Z400S | 3k miles | 3x3 Mod w/ JD Jet Kit | Trailtech Vapor | MCCT | Raptor Petcock | SM Wheels | MRD/Z-Pro | E cams |
  19. #17
    Join Date
    May 2007
    Location
    Great White North
    Posts
    130
    Default
    As stated
    There are 2 oil drain plugs, one under the skid plate and one on the front of the frame behind the front tire, you must drain both.
    Use a new crush washers or you can run in to stripped thread issues.
    Amsoil 20W-50 showed to be very stout based on UOA's for this bike.
    2 quarts works just fine.
    Change the oil every 1000 miles.
    Also lube the chain when doing the oil as it is often overlooked.
    To check the oil ride the bike around the block and get it hot, come home let it sit 3 minutes, check the oil with the bike straight up and down and do not screw the oil cap all the way in, just rest it on top.
  20. #18
    Join Date
    Oct 2010
    Location
    Austin TX
    Posts
    3,033
    Default
    There is also a metal oil filter screen that is at the bottom of the frame in the front frame down tube-
    it has a rubber hose clamped to it -
    it takes a 24mm Deep socket to remove -
    this filter screen is used to stop big chunks of crap -
    Im not 100% sure but I think All the oil that circulates threw the engine goes threw this filter screen-
    when I removed mine it was clean and think I would only remove it after 5 or 10 oil changes or
    if I suspected some type of engine problems because this screen is going to catch the big chunks of metal -
    Link to removing this filter screen--http://www.thumpertalk.com/topic/477...with-pictures/
    2007 WR 450sm --2006 YZ 450sm--2005 DRZ 400sm--2006 YZ 250sm--2005 YZ 250sm
    Gone
    78' SR 500 --73' CR 250 --72' DT 250mx--71' Hodaka Super Rat x2
  21.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
