CRF450 forks on a XR400
Results 1 to 5 of 5
Thread: CRF450 forks on a XR400
  1. #1
    Join Date
    May 2005
    Location
    Cincinnati OH
    Posts
    677
    Default CRF450 forks on a XR400
    Ok all,
    Looks like I'm going to attempt to put 450 inverteds on a xr400.
    The plan is to use aftermarket triple trees, with fat bars, and a lowered set of Cr450 forks.
    Anybody do this, I need to know if the steering stems are the same size, or if I will have to replace the steering bearings, to accomidate the 450 stem.
    Is the neck length the same on both bikes? Will the 450 stem be long enough?
    Toss out your knowledge, It will be appriciated.
    Thanks,
    Brandon
    03 Yamaha YZ450F Supermoto (Race bike)
    01 Yamaha YZ426F Off Road
  2.
    Advertisement
  3. #2
    Join Date
    Jul 2005
    Location
    Newberg, Oregon
    Posts
    307
    Default
    Seems to me that there are several issues present. The steering stems are not the same length and some machining is going to have to be done to get the proper diameter/length. The other problem is the steering stem nut as I believe it needs to be a custom machined part. The last issue is the steering stops...two choices 1)weld on or 2) drill/tap lower triple and place bolts with soft caps to act as stops.
    Check out the XR250/400 forum on ThumperTalk. Do a search and you will find alot of great info. PM Oregon Rider as he has just completed a Ohlins fork swap with LTR.
  4. #3
    Join Date
    May 2005
    Location
    Cincinnati OH
    Posts
    677
    Default
    Thanks,
    I had a feeling the stems would be different, the stops are no problem to fix, and I don't think it will be to much trouble to have a nut made. I'll give TT a look, and post pictures when I get it done.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Oct 2005
    Posts
    4
    Default
    Hey BSC450,
    how did that custom work come out. I have an XR400 and am curious to see what happened with your project. That too crossed my mind a few times.
  7. #5
    Join Date
    May 2005
    Location
    Cincinnati OH
    Posts
    677
    Default
    Monkeybite,
    I'm just starting, let you know when I get eblow deep.
  8.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
