???are yz85 and rm85 hubs the same??
Results 1 to 8 of 8
Thread: ???are yz85 and rm85 hubs the same??
  1. #1
    Join Date
    Jan 2008
    Location
    here
    Posts
    2,844
    Default ???are yz85 and rm85 hubs the same??
    i was told yz85,rm85 are the same for the front use same rotors..and i was told kx85,rm85,yz85 rear was the same is this correct???...
  2.
    Advertisement
  3. #2
    Join Date
    Jan 2009
    Location
    Work
    Posts
    517
    Default
    I think that KX85 and RM85 hubs and rotors are the same due to a parts agreement.
  4. #3
    Join Date
    Jan 2006
    Location
    San Diego CA
    Posts
    2,047
    Default
    Quote Originally Posted by dudesonsfan View Post
    KX and RM 85 front ends were the same a while back, but that ended a couple years ago. The 110's and 125L bikes were identical but the two strokes had some differences. Yamaha was never part of it. I'm not saying the hubs would n't work I'd just double check everything.
    Give Cam at M&M racing a call or email. He'll be able to straighten you out.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Jan 2008
    Location
    here
    Posts
    2,844
    Default
    Nefariousd was the one who told me yz85 and rm85 fronts are the same as far as rotors and spoke count and yz85,rm85,kx85 rear are the same as far as rotors, sprockets just wanting to be sure before I buy...
  7. #5
    Join Date
    Jan 2009
    Location
    Work
    Posts
    517
    Default
    I just thought of it you can always do what I do and google it.
  8. #6
    Join Date
    Nov 2006
    Location
    ROCKLAND COUNTY, NY
    Posts
    410
    Default
    late model RM 85's & YZ 85's use the same wheels, front & rear, the sprockets are the same, the front rotor is interchangeable & the rear rotor is the same. My son has an '06 RM which I have YZ rotors on.
    Cometic Gaskets, Alias, FMF, Vertex Pistons, Factory Connection, KSR Wheels,Gaerne, 100%,Dunlop, UFO,Impulse Design, Pro Taper,
    Moroney's Cycles, Cycle Motion, EVS
  9. #7
    Join Date
    Jan 2008
    Location
    here
    Posts
    2,844
    Default
    cool
  10. #8
    Join Date
    Jul 2008
    Posts
    39
    Default
    I know the KX sprockets have strait holes and the RM has holes that are beveled. You maybe able to just switch the bolts, but I'm not sure.
  11.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
