14,907 miles, 11 clicks out (specified replacement point). I was at four clicks out at 9800 miles. It went fast. The only difference in my riding is the addition of a 40 mile per day commute down the highway. Hmm...
cool, thanks! Is that pretty much the same for most model?? Im lookin at either the 510 or 610. I have seen videos and they look crazy fast especially compared to my little one! lol Thanks alot!
08 TC450, 07 SM610
93 WXC360, 84 CR250
77 360WR, 76 360CR
a GSXR, a YZ, a couple CBR's
and a couple Harleys
how did you remove the nut infront of the flywheel? my penny just crumbled once i attempted to pop that nut
-HUSQVARNA-
Impact gun worked for me ....
You can use the Motion Pro Gear Jammer.
http://www.motionpro.com/motorcycle/..._locking_tool/
2008 Husqvarna SM610
I used a short piece of 3/8" copper tube, scrap from installing a sink.
Flattened an end and then bent it in to a "V", viewed from the end.
It deformed very nicely to the gears and came out in one piece.
It was free and available when I needed it.
Nunquam cum asino ambige.
2006 610sm
past tense: '00 Super Sherpa;'86;CB700SC; '84 FT500; '82 MB5; '78 SR500; '72 CB500; '67 S90
Air gun popped it right off, no problem. now i need to finr a hex to fit the cam bolt, and a socket big enough to hold on to the balancer with
-HUSQVARNA-
Regarding the hex for the cam bolts. Use a new allen key. Several members have attempted to use used ones and have stripped the head, and that cannot be fun to deal with. Do yourself a favor a buy a new one that fits on your socket wrench.
The allen is 5mm. I am not sure which one is the balance shaft but if it's the big one on the (riders) right side that you attempted to jam with a penny, then that one is 38mm.
I bought probably the best supermoto ever made - husky 610 08Because the speedo was reseted? or maby replaced it had 1200km wehn i bought it. Now it has 1800km and it is winter time. Because exhaust valves cover was leaking oil i started to tear down everything...i have to make shure everithing is OK
My cam chain has 8 clicks. Since i am checking valve clerance, gaskets,cleaning everithing up... and everithing si apart i will change chain too. Valves cover will be painted red, just as clutch and ignition covers! This article is just beautiful. Probably better than repair manual!
Greetings from Slovenia, Europe! Luke
Husqvarna SM 610 ´08
Im Doing a cam chain for a friend right now, his tensioner was 15 clicks out
-HUSQVARNA-
How many clicks does it have when its brand new?
Service manual tells you that cam chain should be replaced when there are 10 clicks!
I think in the range of 4-6. I replaced mine recently and then checked it, and was surprised to find the brand new cam chain at 6 clicks.
thanks for the help
-HUSQVARNA-
Question.
The timing mark on the cam gear, is that actually on a tooth, or does it split 2 teeth? cause mine splits 2 teeth, and i can't quite get it to sit at the case like the picture shows, but my cam lobes are all facing down... so am i correct, or should i try again to get that timing mark at the case?
-HUSQVARNA-
I did mine several months ago, but I recall it was pretty much like the photo from Dirty Hucker. I think you would know it if you are off by an entire tooth. Perhaps you can rotate the crank until you get back to TDC and check both marks again. Is the chain properly seated on the bottom gear?
Here is a shot from the service manual. Don't think it helps a whole lot but at least you know.
I changed mine because I also wanted to do a valve adjustment at the same time. Otherwise I would have waited until 9 or 10 clicks. Mine was at 8 clicks at 9000 miles, and I would guess it would have taken another 2000-5000 miles to get to 10 clicks. If you are at eight I would recommend you wait until 9 or 10 clicks.
Changed my cam chain last weekend. Stripped the bike down and brought it over to the dealer and worked on the bike with him. Bought the bike with a worn chain and the difference is night and day. She runs absolutely buttery smooth now.
06 Husqvarna SM610 - Converted SM(TC)450RR
i have almost finished mine... gosh the chain was so nakered! it damaged reed valve and its screw! tensioner was up to the end and chain was loose.
replaced chain and camshaft (water pump mount snapped) and followed Your idea with red paint(painted waterpump cover) also replaced carb breathers for red ones. tomorrow big day. after the covers will dry install and firing up! smashing. hope all will be good...
can you guys post photos of the mounted bike w/ red covers?
also, you guys with tensioners with more than 10 clicks that got the reed valve damaged did you replace it or what?
I need to replace my chain ASAP since I'm at 12 clicks already.. I'll need to buy all the parts overseas so I wanted to know if there are any part not listed that I should also buy just to be safe... (I don't want to start the process and have to wait weeks for a small part)
I have had to replace carbon reed valve plus one screw and also metal protector sleigh on top.
H Guys
....Im now waiting cam chain and will replace it soon as posible,but I will change my piston rings too...
My sm610 has 14.000km(8.500miles).
How many miles I have to ride slower for better snaps because new parts(piston rings,cam chain)?
Thanks
Husqvarna Sm610 i.e 07
After cam chain and piston rings replacement, you should let husky run by itself for few minutes, till rings warm up and fit to clylinder...lets say, warm it up to working temperature and then for cca 100km drive it normaly. There should be no problems. When i do engine overhaul i put cca 1dcl two stroke oil in gas tank, for lover friction...
Hi did you put standard rings or oversized? Cheers
Hello again,today i started the process to change my cam chain.The tensioner was 15 clicks out and the chain was very loose.I bought this bike in this condition and i am doing a full service at this time.I painted the footpegs and the stand black powder coat and the exhaust protectors and engine covers also!I want also to paint rims and swing arm!I will uplod new photos when i'll finish it!Sorry for my English guys!I'm a member from Greece!![]()
I've never ripped apart my 610 but I'm having the valves adjusted along with a few other things at a local shop. Do you have to break the cam chain on a 610 to adjust the valves? And what are the valve specs for intake and exhaust? Any assistance would be greatly appreciated.
Daniel
Husqvarna SM 610
Yamaha YZ450F
you dont have to break chain, just take generator rotor off. and valves are 0.05mm each. try to find manual they are easy to download if can not find i will send you pdf one. cheers
This is a great thread with so much info in it............not that I'm being critical or anything but I think I'm right in saying the OP has got the figure wrong when it comes to the cylinder head nut torque settings (he's quoted 18.4 ft/lbs).
The manual isn't desperately clear (in text or pictures) but I read it as being 27.5 ft/lbs + 90 degreesThis is for the four M10 nuts (two inside the head cover and two on the outside on the rhs as you are sat on the bike).
The manual does also quote a figure of 18.4 ft/lbs which I think is for the single M8 nut which sits at the front of the cylinder between the two exhaust ports.
