'08 530 EXC-R for the street?
Results 1 to 30 of 30
Thread: '08 530 EXC-R for the street?
  1. #1
    Join Date
    Sep 2007
    Posts
    24
    Default '08 530 EXC-R for the street?
    I'm new to the supermoto thing, and I'd like a bike that I can use on the street 80% and 20% in the dirt, so I'm considering the 08 KTM EXC-R 530, and getting the 17" supermoto wheels.
    Am I asking for too much for a bike to be good in street and dirt? Would the 530 be a good supermoto? Thoughts appreciated...
    Thanks.
    Eric G.
    Los Angeles, CA
    2007 KTM 950 SM-R
    08 SXV 550 (sold)
    07 Tuono Factory (sold)
  2.
    Advertisement
  3. #2
    Join Date
    Aug 2006
    Location
    CT
    Posts
    1,403
    Default
    Quote Originally Posted by efgalen View Post
    Thanks.
    Awsome choice, just get 2 sets of brake rotors, and 2 rear sprockets, actually having 2 chains would be a good idea 2, so that you can change the rear sprocket 5-6 teeth easy. If you've got all these goodies you could swap out wheels, and chain and sprockets farly fast, proble 30-45 minites.
    The only thing that gives me difficulty when swapping wheels is the relocator on my front brake caliper, im assuming you will have to have a relocator when your putting on a wider front rim.
    07 XR650R Street Legal SuMo Sold
    04 CBR1000RR
    For Sale: 1997 CR500R $2300, 2005 CRF450R
    06 SMR560 Plated hooligan
    2002 VW GTI 337 1.8T 6 spd Unitronics tuned, 2004 VW GTI VR6 Turbo, 450hp
  4. #3
    Join Date
    Aug 2004
    Location
    dfw/TX/GR
    Posts
    4,854
    Default
    no you have to have a relocator if you have a bigger rotor doesnt have nothing to do with the rim size..
    SUPER MOFO
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    May 2006
    Location
    SAN DIEGO
    Posts
    1,918
    Default
    no, you ar enot asking too much for a bike to be good at both, thats why we have supermotos in the first place!
    good luck and have fun.
    http://www.ginasticanatural.com Fitness training like you've never seen before. Private training in San Diego.
    www.rowdystyle.blogspot.com A good read about a rowdy life.
    08 WR250X & 05 GSXR600 & 07C3
  7. #5
    Join Date
    Oct 2006
    Location
    Troy, MI
    Posts
    819
    Default
    ive heard the new style fork guards on the exc's are wider than last years, which get in the way if your mounting an sm wheel. not sure what people do to fix this though.....
  8. #6
    Join Date
    Dec 2006
    Location
    Mankato MN
    Posts
    713
    Default
    2007 KTM 950 SM-R
    2006 KTM 450 SMR Thanks to Modern Garage and Starr Cycle!
    1999 KTM 300MXC -Woods Weapon
    ***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
  9. #7
    Join Date
    Dec 2008
    Posts
    24
    Default
    i am working on exactly the same conversion. I own a 2008 530 EXC-R and had a lot of fun riding it in the desert. I want to use it now as a commuter bike.
    I got a set of wheels from an aprilia, i have an extra set of front and back sprokets, brakes and chain. I just bought a bracket for the front caliper to be able to fit a front 320mm brake.
    I hope that is all i need as i am gonna do the conversion right after the holidays.
    I was just reading on thumpertalk that KTMs need a lot of maintenance if you start using them as commuter bikes, and that you need to check the valve every week or 2. Not sure if anyone can comment on this.
  10. #8
    Join Date
    Sep 2004
    Posts
    1,487
    Default
    The standard wheels off older KTM supermoto bikes bolt right up to the ex-c, I have done it.
    The brakes are the same as the older KTMs or the brakes KTM sells in the hard parts catalog
    For street fun you probably only need to run a 310 or 310mm rotor with a caliper bracket. But if you plan on doing track days go with a 4 piston caliper as well
    The only problem we had was we had to move the rim over slightly allow for chain/tire clearance - but they may also depend on what tire you end up running
    Awesome bike for the street
    Defunct: SuperMoto Racer magazine
    Part time Blogger: www.motocross.com
  11. #9
    Join Date
    Dec 2008
    Posts
    24
    Default
    thanks smrscott.
    how about the maintenance if you ride it regularly on the road? does it need extensive maintenance and valve check?
  12. #10
    Join Date
    Aug 2005
    Location
    The Idaho Panhandle
    Posts
    1,928
    Default
    I change the oil on my 400EXC about every 1000 miles. Valves havent been out of spec yet. Heavily modded motor, (Big bore, 12.8-1 compression, Cam'd, full exhaust)
    Traded my GSXR 1000 for it and I have no regrets.
    05.5 KTM 950Adventure, The Traveler
    02 KTM 400 EXC Supermoto, The Hooligan
    07 CRF 50, The STUNT MAsheen
  13. #11
    Join Date
    Mar 2005
    Posts
    131
    Default
    To fix the fork guard problem just buy some 2007 fork guards. As for maintance on my 2008 EXC450 I do the oil every 1000 miles and the oil filter every other change. I check the valves every 15 hours and they have only just gone out of spec since first buying it. Its now at 55 hours. You should remember that, yes, they need checking often but generally its just a check-up. All thats involved is removing the tank (leave the shrouds bolted to tank) and then the valve cover. It takes me less than an hour to check them
    P.S. if your wondering why I didn't check it at 60 hours as my maintence schedule suggests its because I could actually hear the engine sounded different, so I checked the valves.
  14. #12
    Join Date
    Dec 2008
    Posts
    24
    Default What a pain...
    Well, i finally found the time to work some more on the conversion.
    I took the time to change the back wheel to the SM wheel and that was relatively painless.
    I still had a problem with the chain last night... it not being shortened yet. So i decided to move to the front wheels and leave the chain for today.
    Well... let me tell you, that sucker was a big pain in the butt!!! the Aprilia wheels that i picked up are a little too wide for my front fork so it was really hard to fit them in.
    I tried to fit them in for at least 20 minutes before i decided to ask my girl to come help hold the caliper in place while i was pushing the wheel in.....after 30 seconds the bike fell on her leg and she's in a cast right now!!!!
    I hope she wont be too upset to see me work on the bike tonight as well
    I got the chain links out today, and as soon as i'll get home tonight i will start putting everything back together! I hope this is the last of it.
    Did anyone put aprilia wheels on a KTM? did you guys have any trouble fitting the front rim in the stock fork?
  15. #13
    Join Date
    Apr 2008
    Location
    manchester, ma
    Posts
    28
    Default
    I have an 08 450 exc-r and had to switch fork leg guards. the 08's were too wide. That and no one can figure out how to reprogram the wheel size in my computer for a 17" wheel. So it always says I'm going faster than I really am. which is kind of annoying.
    06 klx 110
    05 ktm 200 exc
    08 ktm 450 exc-r tarded
  16. #14
    Join Date
    Dec 2008
    Posts
    24
    Default
    seatard, what kind of new guards do i need? do i need to get 07 guards? would these fit?
    Mehdi EB
    Dubai UAE
    '08 KTM 530 EXC-R
    '08 KTM 450 SX (Sold)
  17. #15
    Join Date
    Apr 2008
    Location
    manchester, ma
    Posts
    28
    Default
    07 fork guards. One thing I also noticed is some rubbing on the fork protection ring., that black thing at the bottom of your upper fork tubes with the notches in it. I would also find out about the cam recall. It seems to be more of an issue on the 530's than the 450's.
    06 klx 110
    05 ktm 200 exc
  18. #16
    Join Date
    Dec 2008
    Posts
    24
    Default
    called the local dealer here and told me the 07 guards wont fit on the 08 models...
    anyone can confirm this?
    Mehdi EB
    Dubai UAE
    '08 KTM 530 EXC-R
  19. #17
    Join Date
    Apr 2006
    Location
    Belgium
    Posts
    6,469
    Default
    Quote Originally Posted by ebm31 View Post
    looky what I have bolted straight onto my '08 bike... clueless dealer maybe?
  20. #18
    Join Date
    Dec 2008
    Posts
    24
    Default
    wow!!! looks great! i am sure the dealer is clueless! I'll go get these tomorrow and try to put them on. Right now it is too much of a pain to try and put the front tire in.
    Where did you get your graphics from? or where can i get cool graphics for a fair price?
    Mehdi EB
    Dubai UAE
    '08 KTM 530 EXC-R
  21. #19
    Join Date
    Apr 2006
    Location
    Belgium
    Posts
    6,469
    Default
    custom graphics, allready got another set that's supposed to go on after winter's over. pricey compared to the graphics you can buy from one industries or other makes but you do get one of a kind stuff.
    '07 guards will bolt right up.
  22. #20
    Join Date
    Dec 2008
    Posts
    24
    Default
    do you have to buy new plastics for the graphics? my dealer said that the 08 have printed stuff on the front side pastics so you have to buy a new set or it'll show through your new set of graphics. true?
    Mehdi EB
    Dubai UAE
    '08 KTM 530 EXC-R
  23. #21
    Join Date
    Apr 2006
    Location
    Belgium
    Posts
    6,469
    Default
    They're white plastics so I had to get a new set.
  24. #22
    Join Date
    Dec 2008
    Location
    Redlands
    Posts
    106
    Default
    i have your same bike and i have to say your dealer is full of shit and just wants to sell you plastics, i had some graphics made for my bike and you couldnt see anything through them
    2005 KTM 625SMC w/ Leo Vince X3's
  25. #23
    Join Date
    Mar 2005
    Posts
    131
    Default
    seatard there is a way to reprogram it. If i remember correctly i had to remove a 3 pin connecter from the back of for unit then hold the button on the right hand size, this let me change the wheel size. Although remember you want to enter the wheel size with the tyre fitted.
  26. #24
    Join Date
    Dec 2008
    Posts
    24
    Default
    Quote Originally Posted by ktmnick909 View Post
    I am starting to see that! this guy wants to sell me something everytime I enter his shop! !@#$%
    Thank god for SMJ
    Mehdi EB
    Dubai UAE
    '08 KTM 530 EXC-R
  27. #25
    Join Date
    Apr 2008
    Location
    manchester, ma
    Posts
    28
    Default
    I like the step seat on the white exc. is that a ktm factory part?
    06 klx 110
    05 ktm 200 exc
  28. #26
    Join Date
    Apr 2006
    Location
    Belgium
    Posts
    6,469
    Default
    Quote Originally Posted by seatard View Post
    indeed it is
    Factory step up seat
    partnr: 78007240100
  29. #27
    Join Date
    Nov 2008
    Location
    Fresno, Ca.
    Posts
    111
    Default
    What size sproket you runnin on that commuter?
    I was thinking to try a 42 tooth on the rear and a 15 in the front since you cant get/fit a 16 on the front.
    Oh and yall prolly know about this... But in case you do not it works GREAT!! Enjoy: http://www.gearingcommander.com/
    Michael
  30. #28
    Join Date
    Jun 2007
    Posts
    21
    Default
    Thanks.
    I have done just that and I could not be happier with my choice. I still want to get a 320mm rotor and another rear rotor so I do not have to swap them out when I switch between dirt and sm. So far I have very few miles on the sm setup but I dig it. I am running 14x46 for gearing and it fells just like the 14x50 on the dirt setup. I may do 15x46 for highway trips.
    Graphics will go right over the stock graphics, no problem.
  31. #29
    Join Date
    Feb 2009
    Location
    Northeast Ohio
    Posts
    119
    Default
    Bike looks great man! Good job!
  32. #30
    Join Date
    Jul 2008
    Posts
    53
    Default
    Seatard - just went through this on my 08 450 excr. You need to remove the front light and unplug the computer from all connections. Once unplugged hold the menu button on the right side of the computer and cycle through the menu until you get to WS - then you can press +/- and adjust as needed. I measured mine (17"s with distanzia's and they were 1845mm). Plugged everything back up and it worked...until my sensor stopped working!! Still working to fix that problem
  33.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
