DRZ 400 Jet Kit question
Results 1 to 41 of 41
Thread: DRZ 400 Jet Kit question
  1. #1
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default DRZ 400 Jet Kit question
    I'm looking at buying a new DRZ 400 and was looking online to see what would be the best jet kit to buy. The Yoshimura website says you only need to change out the main jet to a # 145, does this sound right? And if so how much should the jet kit cost me?
    __________
    07 VW GTI
    07 DRZ 400SM
  2.
    Advertisement
  3. #2
    Join Date
    Dec 2005
    Posts
    8
    Default
    The dynojet kit was the thing when I did mine a few years ago. (S model) Call jessie at kientech and talk to him. He has all the right stuff and a great guy to deal with. Get his extended fuel screw and float boal screws as well.
    http://kientech.com/
  4. #3
    Join Date
    Aug 2006
    Location
    Harrisburg, PA
    Posts
    628
    Default
    It all matters if you are cutting a 3x3 hole in the air box and if your adding a pipe. Check thumpertalk.com, they have tons of info on this. I have a 155mj, dynojet needle, 3x3, and stock pipe on mine. Your average altitude level plays a role too.
    the dynojet kit is expensive but they give you a bunch of jets to try to get the correct jetting.
    07 RMZ 450 SM
    96 XR 600R SM
    03 CRF 150F SM
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    May 2005
    Location
    Marshall, MI
    Posts
    1,269
    Default
    DRZ400 can come with 2 differant carbs depending on the model make sure you get the kit for the correct model.
  7. #5
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Cool thanks. Yea I was planning on doing the 3x3 and the full rs-2 yosh, but just wasn't sure about the jetting. Thanks!
    __________
    07 VW GTI
    07 DRZ 400SM
  8. #6
    Join Date
    May 2007
    Location
    RI
    Posts
    2,638
    Default
    Get the jd jet kit. It comes with the 25 pilot jet, the dynojet kit does not. You will also want to order the allen head float bowl screws and an extended fuel screw for easy adjustment.
  9. #7
    Join Date
    Aug 2006
    Location
    East End, Long Island, NY
    Posts
    522
    Default
    With a full aftermarket exhaust and 3x3, you will want to change both the pilot and main jet. Exactly what sizes will depend on your altitude.
    Go to Thumpertalk.com. Eddie Cisneros there (aka Burned) is pretty much the guru of DRZ jetting, and if you don't find your answer with a Search (and believe me ... someone there has already asked it), Eddie can help you out.
  10. #8
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Does anyone have a picture of where the 3x3 is to be cut in the airbox?
    __________
    07 VW GTI
    07 DRZ 400SM
  11. #9
    Join Date
    Aug 2006
    Location
    Harrisburg, PA
    Posts
    628
    Default
    i can get a picture this weekend. But mines cut right at the top. From the rear up to the nipples for the computer.
    07 RMZ 450 SM
    96 XR 600R SM
    03 CRF 150F SM
  12. #10
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Cool thanks man!
    __________
    07 VW GTI
    07 DRZ 400SM
  13. #11
    Join Date
    Jan 2007
    Location
    Shingle Springs, CA
    Posts
    1,148
    Default
    Here is a link to the master 3x3 mod thread at Thumpertalk. Everything you need to kow, plus pics, is in it.
    http://www.thumpertalk.com/forum/sho...ght=master+3x3
  14. #12
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Cool thanks.
    Anyone know anything about Moose Racing Jet kits?
    __________
    07 VW GTI
    07 DRZ 400SM
  15. #13
    Join Date
    Mar 2007
    Location
    Columbus, GA
    Posts
    85
    Default
    I know that the moose kit is dynojet with both moose and dynojet emblems on the box. When I ordered my from a local guy I told him the DJ part number, he ordered it through Parts Unlimitted and when it arrived it said moose as well. If you get the SM kit (3110) here is what worked for me with the RS2:
    25 pilot (bought seperate from the kit)
    160 main
    jet clip in 4th from top with all stock spacers.
    Fuel screw 2.75 turns out.
  16. #14
    Join Date
    Jun 2007
    Posts
    82
    Default
    FijiDickie.....Im glad you posted this, cause I was going to.
  17. #15
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Ok so does anyone know when you cut the 3x3 is it partially covered by this electronic box that fits onto the two columns?
    __________
    07 VW GTI
    07 DRZ 400SM
  18. #16
    Join Date
    May 2007
    Location
    RI
    Posts
    2,638
    Default
    Quote Originally Posted by Fijidickie View Post
    yes it is partially covered!
  19. #17
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Ok so with the full yosh, the moose racing/dynojet kit, and the 3x3, what types of increases should I be getting?
    __________
    07 VW GTI
    07 DRZ 400SM
  20. #18
    Join Date
    Aug 2006
    Location
    Harrisburg, PA
    Posts
    628
    Default
    some, not a ton, but its the least you can do to allow the bikes potential
    07 RMZ 450 SM
    96 XR 600R SM
    03 CRF 150F SM
  21. #19
    Join Date
    Dec 2004
    Location
    Tucson, AZ
    Posts
    54
    Default
    uh oh, Dickie got a DRZ too !!!!
  22. #20
    Join Date
    May 2007
    Location
    RI
    Posts
    2,638
    Default
    3-4 hp gain. If you get the moose racing/dynojet kit make sure you order a 25 pilot jet as it is not supplied. You may also want to order the hex head float bowl screws, you'll need them.
  23. #21
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Cool thanks for the tip!
    __________
    07 VW GTI
    07 DRZ 400SM
  24. #22
    Join Date
    Aug 2006
    Location
    Harrisburg, PA
    Posts
    628
    Default
    Use allen heads that you can get at the local hardware store. Those phillip/ diamond head bolts strip too easily.
    07 RMZ 450 SM
    96 XR 600R SM
    03 CRF 150F SM
  25. #23
    Join Date
    Jul 2007
    Location
    Vancouver, Wa
    Posts
    33
    Default
    Recomendations are just that. Recomendations. Start there and tune the bike. For some reason, my bike was way too lean at the recomended settings. I wound up going with a 27.5 pilot, 165 main, DJ needle on 5th clip, and the air screw 3 turns out. Runs much stronger everywhere and I have a nice brown plug.
    05 DRZ400SM- Yosh exhaust, dj, hotcams stg 1, 3x3, baja designs tail light, led mini stalks.
  26. #24
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Cool, now someone explain to me why the pilot jet is so important to change? Sorry I'm kinda new at this...
    __________
    07 VW GTI
    07 DRZ 400SM
  27. #25
    Join Date
    Jul 2007
    Location
    Vancouver, Wa
    Posts
    33
    Default
    The pilot jet will richen up the mixture at idle. The needle effects midrange (and a bit of top end) and the main jet is all top end.
  28. #26
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Ok so if you are not having any problems at idle, then don't worry about it?
    __________
    07 VW GTI
    07 DRZ 400SM
  29. #27
    Join Date
    Feb 2007
    Location
    OKC, OK
    Posts
    377
    Default
    The pilot jet does not affect idle. Idle is handled by the fuel/air screw. The pilot jet is for approximately the first 1/4 of throttle position, any amount of throttle at all up to 1/4 throttle or so. If the pilot is too small you get that sputtering lack of power feeling in the first quarter of throttle..then after you open it up, it goes away. Also you get the surging behavior at cruising speeds since cruising usually happens at 1/4 or less throttle. If you are experiencing that, then your pilot jet is too small. Its really not a guessing game. Certain settings are correct for certain elevations. Its pretty scientific actually.
    2007 DR-Z400SM - Black
    2008 Ducati Hypermotard 1100S - Red
  30. #28
    Join Date
    Jul 2007
    Location
    Vancouver, Wa
    Posts
    33
    Default
    Doesn't pilot affect air screw adjustment?
  31. #29
    Join Date
    Feb 2007
    Location
    OKC, OK
    Posts
    377
    Default
    It does, but you shouldnt use screw adjustment as a substitute for the correct sized pilot jet. Your biggest indicator of an improper pilot jet is surging at cruising speeds, because you might still be able to get it to idle properly with the screw turned all the way out (or in), but thats not leaving any room for adjustment and doesnt solve the problem of surging in the lower throttle range.
    I guess i shouldn't have said the pilot doesnt affect idle, because it does in a way. What i meant was the fuel screw only affects idle, so if idle is your only problem and it performs well everywhere else in the throttle range then you should adjust the fuel screw. However if you are having problems with getting it to idle, or you have to turn the screw all the way out (or in) to get it to idle, you are likely having problems elsewhere in the throttle range too. But just because you can get it to idle doesnt mean its right. Gotta check all ranges of throttle position.
  32. #30
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Do you know what pilot jet comes standard on the DRZ 400sm?
    __________
    07 VW GTI
    07 DRZ 400SM
  33. #31
    Join Date
    Oct 2007
    Location
    wisbech
    Posts
    13
    Default
    hi i just got a new fmf power bomb down pipe and Remus Revolution Titanium Exhaust end can, K&N and R&G tail light can any one tell me what jet to fit and is there anything i need thanks wayne
  34. #32
    Join Date
    May 2007
    Location
    RI
    Posts
    2,638
    Default
    22.5
  35. #33
    Join Date
    Jul 2007
    Location
    Manassas, VA
    Posts
    69
    Default
    Okay, so I just installed a Yosh Pipe and 3x3 on my SM, along with a 150 jet, and adjusted the pilot screw out 1 1/2 turns, like the instructions say. Now, it does NOT like to idle.... Uhm... help?
    Dan
  36. #34
    Join Date
    Feb 2007
    Location
    OKC, OK
    Posts
    377
    Default
    Quote Originally Posted by Lt. Dan View Post
    Dan
    What jet kit did you use? If you installed a full exhaust and did the 3x3 mod you will need a 25 pilot jet as well. The Dynojet kit doesn't come with it but the instructions should still say to get one and install it.
    and for anyone else who bought a full exhaust and wants to do the 3x3 mod..just buy a jet kit. Its the easiest thing to do.
  37. #35
    Join Date
    Jul 2007
    Location
    Manassas, VA
    Posts
    69
    Default
    Quote Originally Posted by ObiWan View Post
    Well, I didn't use a jet kit... I just followed the directions that came with the Yoh exhaust... It said to install a #145 jet, and turn the pilot screw out 1 1/2 times. Don't worry, just called and ordered a jet kit... guess I'll have to play with it a bit...
  38. #36
    Join Date
    Feb 2007
    Location
    OKC, OK
    Posts
    377
    Default
    That would have worked if you hadn't done the 3x3 mod. Now that its done you'll need that kit you ordered. Gonna need a much bigger main and a bigger pilot plus you'll need to use the needle from the kit since the main jets in the kit will be alot bigger than stock.
  39. #37
    Join Date
    Sep 2007
    Posts
    58
    Default
    I have an 06 DRZ400SM and I'm doing similar mods...3x3...dynojet with 25 pilot jet, full Yoshi RS-2....
    I live in Phoenix (sea level, warm, dry) and people are recommending:
    160 main
    dynojet 3rd or 4th clip
    25 pilot
    2-2.75 turns out
    I should have it put together in a week. I'll post the results.
    [SIGPIC][/SIGPIC]06 Suzuki DRZ400SM: Yellow, Yoshi, 3x3, jetted
    05 Toyota Tacoma TRD Sport, murdered out (black on black): 3" Rev Tech, 285s on 18" American Racing Teflon Mojaves, AFM intake, Gibson exhaust
    07 Suzuki LTR 450: White, Two Bros., cherry bomb
  40. #38
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    Yea the dyno jet kit I think says 3 turns out, but you are replacing the main and the needle... And the main I put on was a 155 I believe...
    __________
    07 VW GTI
    07 DRZ 400SM
  41. #39
    Join Date
    Sep 2007
    Posts
    58
    Default
    What clip position did you use, 3 or 4 from top?
  42. #40
    Join Date
    Oct 2007
    Location
    JAX FL
    Posts
    58
    Default
    2 from the top
    __________
    07 VW GTI
    07 DRZ 400SM
  43. #41
    Join Date
    Nov 2006
    Location
    Truckee, California
    Posts
    2
    Default Burned is the man...
    By far the easiest thing to do is go to the Thumpertalk forum and search the DR-Z400 threads for jetting information from Eddie Cisneros, aka "Burned".
    Burned is the DR-Z tuning/jetting guru and whatever combination of exhaust and elevation you're dealing with, he's answered the question at least once.
    Regarding jetting kits: yes, you can just go to your local dirtbike or snowmobile shop and buy only the jets you need. The main reason that people buy the Dynojet or JD kit is that the kits come with a replacement needle that has a different taper than the stock unit. I live and ride at about 6,000 feet, so I changed the needle and the pilot jet only - the stock main jet was actually what Burned recommended for my elevation, although it would be wicked lean at sea level. This is with the 3x3 mod and the stock exhaust system.
    Pete Bansen
    Truckee, California
    '04 DR-Z400S
    '04 R1150GS Adventure
  44.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
