just for looks then eigh? hahah they aresick!!!
hey guys, while waiting for paint to dry i got a little antsy and trimmed some more plastic goodies on my bike...
go look at yours and youll see the diffrence.
i also got a new chainguide setup for a little experimentation...
just a little paint and imagination, see how different it looks now? I would like to powdercoat the swingarm and frame soon as well, grey looks cheap after 5k miles. and being bashed on the bike stand.
does anyone have pics about the smog removal?
Nuno Alexandre
2009 husky 530RR (the best bike ever made)
2008 ktm duke 690
I've posted Speedzilla's SM610 mega thread for you a couple of times....I see you have not read it yet since you keep posting the same emission removal questions. So, since you don't want to read the most comprehensive guide to everything that is the SM 610, I have your answer......
"Originally Posted by Dave
Dukepilot, have you removed the emisssions junk yet?
Yup, it's history. Pretty easy to do.
Disconnect the carb vent lines/fuel lines and remove the tank and the headlight unit.
Take a look at what goes where... where the hoses go.
Remove the manifold that is zip tied by the ignition switch
Remove the small cannister attached to the lower triple
Disconnect the hoses that connect to the pink carb vent lines and reroute the vent hoses
Disconnect the hose from the nipple on the intake side of the head, near the carb boot and plug it up with an automotive vacuum plug
Remove the large cannister and attached hoses.
Install one of those little aluminum no spill fuel vent fittings to the top fuel vent nipple on the tank.
Reinstall the tank and headlight and you're good to go. Don't forget to plug the nipple on the side of the head. It is a vacuum line and will suck air otherwise.
I routed the top carb vent lines to a location under the seat and used one of the left over T fittings to connect the lower carb vent hoses (not the carb bowl drain line) and installed a filter and one way valve to keep shit out of the carb. Also rerouted the crankcase vent from the airbox, plugged the hole left in the airbox and capped of the vent hose with a K and N vent filter. Took about 30 minutes to do in total"
Your's may not have all the smog/emission equipment on it since it is not a North American model & since we in the States have not received any EFI models as of today, I'm not sure if it does either. GL
2006 Husqvarna SM610
2007 KTM XC-W 400
2001 Honda GL1800
1980 Yamaha SR500
1972 Kawasaki G4TR "Trail Boss"
thanks a lot man i will see how it works on the FI.
Nuno Alexandre
2008 ktm duke 690
hehe , if I have not mistaken EFI 610 has no such smog stuff =))
I finally able to get a CRG lever mounted onto my SM610.
'07 Husky SM 610
pardon me but wholly shit! thats nice, what dimensions (borexstroke) did you go with? better yet, whats the PN and price???
sweet, but it looks like you replaced more then just a lever, what master is that?
Current:
KTM 380SMR - 2T (plated supermoto)
Way back when:
KTM 625SMC | Husqvarna SMR570 | Husqvarna SMR510 | Honda XR650
Looks great, but my stock front brake set up is more than enuf to flip me over "stoppie style."
'96 Yamaha WR250
'04 KTM 525 SMR
'04 Yamaha YZ125
'09 Honda XR650L
It took me 7 months to locate an 04-07 R1 front brake M/C. Same as 05-07 R6 Its factory brembo unit. Same one use on some Ducs. I found someone local who was parting out his track bike. Got it for $30. The brake reservoir is from the same bike. I used the rear brake reservoir. I just zip tied the reservoir to the throttle cable. Original was plenty stopping power. but i always wanted an aftermarket lever.
'07 Husky SM 610
dude get your self a piece of flat 1/2' steel stock and drill two holes, one on either end, mount one end on your lever clamp and the other to your reservoir... zip ties... pfft what do you think youre riding, a 610??
my rear fender is held on by ziptes now... hahahaa
bah, steel=weight, lol I'm going to home depot to get some aluminum bar stock. It was late and i wanted to mount the M/C.With how it sits now. If the bike goes down. I don't have to worry about the reservoir breaking off.
'07 Husky SM 610
That is some good zip tie thinking. I would just leave it. It works, right?
2006 HUSKY SM610
hey wondering if anyone as tried this on their x3 full system? I will let you know in a few if not!!
http://www.leovinceusa.com/fastbox/fastbox.php
2006 HUSKY SM610
Does anyone know what is necessary to change the tank to a tank of a 570?
Good idea DH.![]()
Here's how to liberate your stock can of its stooopid sound baffles and cats
http://www.supermotojunkie.com/showthread.php?t=52974
-Derek
Plated Scoots: '01 FS650 // ''97 CR500SM // '06 YZ250 // '98 RM250 // '86 XR250
Boring Street Bikes: '98 Ducati M900 // '07 XB12SCG
Nice job Snarf. You made the job sound pretty simple. What did you use to secure the end caps back on? What's your jetting like now with the exhaust opened up? Thanks for the info.
I just used another set of blind rivets, and a rivet gun to pop them in place. As for jetting, i haven't touched it yet, but am planning on ordering a JD kit on Monday, as well as doing the AP mod this afternoon. I'll report back afterwards with how things went.
-Derek
Thought it worth adding to this thread.
4300-4800rpm stutter completely cured and decel pop almost comletely cured by the iridium plug.
Not sure if that's simply because it's a nice new, clean plug, or the fact that it's a different spec. Will see further down the track, I guess.
I bought this bike with 2000km on it. I put 1000km on it before changing the muffler, and another 2000km since. At 5000 km the original plug showed the bike to be running slightly rich.
The iridium plug and Barrett end can are the only engine mods I've made. Jetting and air filter are stock, and fuel screw is in stock position.
Power wheelies in second will flip the bike if I really try. Powers up with a little bump or throttle chop in third, or clutches up fairly easily.
Edit/Delete Message
Well, after messing around with a few different settings, here is the best setup I have found for my mods, temp [50F or below] and alt [central KY]
Stock needle in the 5th slot [4th is stock]
178 main
stock pilot [50]
AP mod, using an oring froman oring chain masterlink
The bike runs pretty darn good now.. although i wonder if I need to go richer with the main, the bike seems to just wind off a bit int he higher revs.. granted thats in 5th and 6th gear, nothign gonna pull ral hard there, but, i digress.
The bike is still doing the ever so slight pop around 4500 so many of us talk about. Next up on the mods list is an iridium plug, and messing with disconnecting the TPS
After that, im gonna convert the stock can to a true straight through setup with a perforated core. A it stands right now, its just a big open chamer, and its prolly got tons of turbulence.. theres prolly a lil more power up top in there if I let the exhaust escape smoothly..
-Derek
Just a little update- I disconnected the TPS, and switched to the iridium NGK plug [CR8EIX], and the 4500=ish hiccup/stutter is completely gone.
-Derek
Mounted a 7S battery this weekend. Quite a bit smaller than the stocker or standard replacement.
Glued rubber to the floor of the tray and made two aluminum brackets, one for each side. Bend the top over to accomodate the rubber retention strap. Riveted the brackets onto the tray.
Glued two 1" rubber stoppers together then cut to fit the distance between the fender and the battery. Drilled a small hole through the fender and the stoppers. Rubber cemented the base of the stopper to the fender and scewed the stopper in place using a sheet metal screw (use a fender washer under the screw head to prevent fatique).
Use the stock retention strap side to side.
Use the tool retention band for where the old strap went.
Battery won't go anywhere, terminals are nowhere near the subframe. Ground strap and power take off won't chafe. Don't need any foam.
NoPoz
Wow, i just read though all these mods and i don't know which one i wanna do first. Thanks everyone for all the great ideas!!!!
-Sm610
-Yz450
-Bobcat753
[SIGPIC][/SIGPIC]
Anyone have any more info/pics on the airbox mod. I already gutted it out, I am ordering the 3190 tonight but was wondering how people were mounting the side panels back on.
Thanks
Looks like a tight fit, i hope it works.
-Sm610
-Yz450
-Bobcat753
[SIGPIC][/SIGPIC]
Sweet thanks hucker, so you are just running with outer cover only and remounted the brake reservoir. I cannot wait.
-Sm610
-Yz450
-Bobcat753
[SIGPIC][/SIGPIC]
All you have to do is cut the box off just inside the cover bolts that way you can still bolt the left over part of the box onto the mounting bolts and then bolt the cover back on to the left over box. Hope that makes sense?
Or you could just do this mod!![]()
2006 HUSKY SM610
Hell yea that is a sweet mod!!!!
Yea i was trying to figure a way to do it without destroying the stock airbox, with the gains everyone reports from the mod i guess i will just have to commit, Thanks for you help.
-Sm610
-Yz450
-Bobcat753
[SIGPIC][/SIGPIC]
OK Hapamoto, give it up!
Show some more pics and give details, that looks pretty cool and I guess you
avoided the mangling of the 3190 model against the frame, huh?
Not sure how much if any performance I gained from doing this since I did the air box, filter, plug and rejet all at the same time, but it seems like it should help something?????this is the intake side of the carb. If you look at your is will have casting marks and square edges!
2006 HUSKY SM610
That exhaust is gorgeous, more pics please.![]()
Nice!
-Sm610
-Yz450
-Bobcat753
[SIGPIC][/SIGPIC]
gotta like the sound of that air box mod!! sounds like a bird chriping almost![]()
2006 HUSKY SM610
Ne, schau mal einer an. Der Eberhard !![]()
Jepp, die Jungs hier sind recht experimentierfreudig - hab schon manch gute Anregung bekommen.
Gruß,
Eberhard sorry for this german crap![]()
awwwwww man!!! yeah i agree with what he said... definatly a nice pipe ya got there...
