cr500 tuning
Results 1 to 15 of 15
Thread: cr500 tuning
  1. #1
    Join Date
    Nov 2006
    Posts
    1
    Default cr500 tuning
    is it true the best year for power was 1985 if so i want exhaust port sizes to compare with a 1998 thanks for any help
  2.
    Advertisement
  3. #2
    Join Date
    Mar 2005
    Location
    York SC - just below Charlotte
    Posts
    8,617
    Default
    From what I understand the 5 huneys have been de tuned each year since the 84 air cooled version.
    www.MotoHose.com
    Don't bring a gun to a snowball fight!
  4. #3
    Join Date
    Oct 2005
    Location
    CT
    Posts
    921
    Default
    peak power is not the same as useable power. the 80s bikes do have more power but The 90s bikes are supposed to have smoother power delivery which makes for more useable power. From 91 or 92 on they are basically the exact same up through their end in 2001. which is best for your application is for you to decide
    CR500 Street Tard blacked out with Baja Designs race light kit & full port & polished motor
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2004
    Location
    dfw/TX/GR
    Posts
    4,854
    Default
    my CR500's front wheel hates the ground and it's a 1990... not sure why i picked a CR500 to build a motard..
    SUPER MOFO
  7. #5
    Join Date
    Feb 2006
    Posts
    125
    Default
    If you need the "feel" of more power, run stock dirt gearing on the pavement. The whellies are almost uncontrollable.
    I am tall enough to be your dad.
  8. #6
    Join Date
    Oct 2004
    Location
    Iles Anglo Normande
    Posts
    111
    Default
    The 1986 is the one you are talking about.
    After that the barrels had scallops to make starting easier.
    Go to www.cr500riders.com
    They will answer all of your questions....
  9. #7
    Join Date
    Mar 2005
    Location
    Posts
    8,617
    Default
    Scallops??? What is that?
    www.MotoHose.com
  10. #8
    Join Date
    Aug 2004
    Location
    dfw/TX/GR
    Posts
    4,854
    Default
    Quote Originally Posted by bully
    No they wouldnt... you have to own a CR500.. but everyone is free to use the search button (lots of good info for the CR500)
    SUPER MOFO
  11. #9
    Join Date
    Feb 2005
    Location
    So-Cal
    Posts
    797
    Default
    some of that powerband technology has more to do with "port timing", which on a two stroke is where the port window heighth is in relation to the deck or top of cases..like cam lift heighths or cam timing to a thumper...certain heighths will give over rev and a screaming top end and some will give immediatte roll on torque or a big rush that signs off early.....ive known guys to shim the bottom of the barrel and then shave the crap out of the head to get a screaming top end but it runs like crap off an idle.....i think through the years honda changed these intake and exhaust port heighths (within the cylinder), compressions, intake tract lengths (different reed cages and boot lengths on the older motors), headpipe lengths, and even the stroke and bore if you are going all out....i think 86 is the most horsepower year but hardly useable or rideable in most situations, just my 10 cents! you'd be amazed what you can feel as far as differences by just modifying the compression, jetting, and headpipe lengths. CR500 riders is very good for info. as far as i know you own a 98 CR500
    Steer with the throttle , eh?
  12. #10
    Join Date
    Aug 2005
    Posts
    15
    Default
    Quote Originally Posted by apa
    Scallops are very light exhaust reliefs in the exhaust porting. Which i saw someone say they are for easier starting. That is correct. Most of the reason the 85-86 CR500 motors had more power was due to the thinner barrels and higher compression heads. The later models like from 89-01 had a thicker barrel due to stress cracks the 85-86 barrels always had. In 89-01 honda lowered the compression a lot. If you ever look at a 86 head and a 90 head the step on the inside of the combustion area is double the thickness on the later model CR500. Shave the head on the later models, and watch the horsepower grow. There is a few companies now that have a starting relief valve that can be drilled into the exhaust side of the barrel making starting a high compression - high horsepower CR500 motor feel like a CR125. The valve is open before starting and will stay open tell the motor fires. This is the best thing you could ever do for tons of easy starting. Just my 2 cents on works good for me.
  13. #11
    Join Date
    Nov 2006
    Location
    Leesburg/Albany GA
    Posts
    161
    Default
    Where is a "barrel" at on a 2 stroke?
  14. #12
    Join Date
    Mar 2005
    Location
    Posts
    8,617
    Default
    barrel=cylinder
    www.MotoHose.com
  15. #13
    Join Date
    Oct 2006
    Location
    Owensboro Ky
    Posts
    264
    Default
    The "scallops" were like "eyebrows" on the exhaust port. Going to the 2nd oversize will eliminate the "scallops". The CR500 porting , as powerful as it is stock, is actually pretty tame compared to what it is capable of. Another trick to easier starting was to drill 2 holes in from the exhaust port to the bore. At low rpm, this would act as a compression release, where at higher rpm, their affect was nil. 80 rwhp is easily achievable with this motor with just porting, case mods and pipe/carb. Just have to ride it like a 125...easier said than done. Tdub
    Fast Forward Performance
    Home of Amateur National Champions
  16. #14
    Join Date
    Nov 2006
    Location
    Leesburg/Albany GA
    Posts
    161
    Default
    barrel=cylinder
    Wow. Never heard it called that.
    But I have heard some rednecks around here call it a "jug". lol.
  17. #15
    Join Date
    Sep 2006
    Location
    Valley of the Sunburn
    Posts
    3,270
    Default
    I can say that a tweaked 86 500 motor is huge on power, low on "rideability". I used to have a '85 bike w/ a '86 motor. I didn't bring it w/ me to AZ and my cousin's buddy burned it up not running pre-mix. I miss that damn beast.
    Frustra fit per plura quod potest fieri per pauciora
    A little nonsense now and then is relished by the wisest men.
    *We* are the music makers... and *we* are the dreamers of dreams.
  18.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
