Bad Clutch basket?
Results 1 to 6 of 6
Thread: Bad Clutch basket?
  1. #1
    Join Date
    Jul 2008
    Location
    SUSSEX, NEW JERSEY
    Posts
    284
    Default Bad Clutch basket?
    I've never seen a bad clutch basket. My clutch started Engaging really rough in first gear a few weeks ago. I took it apart today and found groves in the basket. Would like to see more pics of good and bad clutches.
    Here's the bad groves.
    07 610 SM (gone)
    08 530 SMR
  2.
    Advertisement
  3. #2
    Join Date
    Mar 2007
    Posts
    6,362
    Items for Sale
    Default
    Yeah it's worn good. Is the clutch kinda sticky? You can take a file and smooth them out, but that's a bandaid fix. The problem will come back.
    2006 husqvarna 530rr. AKA "dirtyfivethirty" or "freight train " Formerly known as Alohar1
    www.FastBikeIndustries.com www.ksrwheels.comwww.balidogrefuge.com
  4. #3
    Join Date
    Jul 2008
    Location
    SUSSEX, NEW JERSEY
    Posts
    284
    Default
    Quote Originally Posted by 06-530rr View Post
    Yes the clutch is sticky. It would grab really rough hard when cold then it would get better after it warmed up. I Already took a file to it last night. It was pretty late to get a test run in but it did feel a lot better.
    07 610 SM (gone)
    08 530 SMR
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Jul 2008
    Location
    SUSSEX, NEW JERSEY
    Posts
    284
    Default
    After the filling
    07 610 SM (gone)
    08 530 SMR
  7. #5
    Join Date
    Jan 2007
    Location
    Staten Island, NY
    Posts
    892
    Items for Sale
    Default
    there's a tolerance in that gap that needs to be maintained. do you know if all the springs were tightened correctly, where you able to feel the same pressure when you removed them? I swear I even seen shops do worse than just get the torque wrong on those springs
    NORTHEAST METZLER/PIRELLI SUPERMOTO TIRE DEALER
    WWW.HAMMARACING.COM
    CRF450R, KXF450, CRF100, CRF150F, CRF250R, '82V45 Sabre '00 Aprilia SR50, 82 Yamaha XJ650RJ Seca, '72 RD350 R5
    http://www.youtube.com/watch_popup?v=xdj67XknFrM#t=5
  8. #6
    Join Date
    Oct 2005
    Location
    NY State
    Posts
    444
    Default
    Its def worn pretty good. Filing and deburing the edges will help smoothen the engagement and get you back on the road. At some point its gonna need to be replaced.
  9.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
