Pitster Pro XTR 250
Results 1 to 6 of 6
Thread: Pitster Pro XTR 250
  1. #1
    Join Date
    Oct 2008
    Posts
    1,207
    Default Pitster Pro XTR 250
    Looks sweet.. Will hopefully be available on Octoberish..
  2.
    Advertisement
  3. #2
    Join Date
    Mar 2012
    Location
    Woodville, NY
    Posts
    1,339
    Default
    wow, not bad
  4. #3
    Join Date
    Apr 2006
    Location
    O-Town, FL
    Posts
    3,712
    Default
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Apr 2008
    Location
    Franklin, NC
    Posts
    9,327
    Items for Sale
    Default
    Quote Originally Posted by daddysmut View Post
    $2800, I'd own one.
    www.FastBikeIndustries.com
    "Just stay in the fast lane, and keep moving, you cannot predict your final day, so go hard for the good times while you can." Kenny Stabler
    '08 DRZ 400sm - FCR, E cams, SSW / MRD, Tuned by Wheeler
    '02 XR 50 - 1/4 scale stunt bike
  7. #5
    Join Date
    Oct 2008
    Posts
    1,207
    Default
    Yea, they have em already in Canada with a 200cc motor but not legal in the US..
    http://www.pitsterpro.ca/en/products...supermoto.html
    Bike Model
    Model : XTR 200X SUPERMOTO
    MSRP : $2,799
    Engine
    ENGINE : Four-stroke Single
    DISPLACEMENT : 199cc
    BORE & STROKE : 66 mm x 58.2 mm
    COMPRESSION RATIO : 9.4:1
    COOLING : Air cooled
    IGNITION : CDI
    STARTER : Electric
    TRANSMISSION : Five-speed manual clutch
    WHEELS AND TIRES
    FRONT TIRE : 110/70-17
    REAR TIRE : 130/70-17
    DRY WEIGHT : 271 lb (123 kg)
    FUEL CAPACITY : 10.6L
    GROUND CLEARANCE : 10.6” (270 mm)
    OVERALL LENGTH : 86.6” ( 2199 mm)
    OVERALL WIDTH : 32.6” ( 828 mm)
    SEAT HEIGHT : 31” (788 mm)
    WHEELBASE : 55.3” (1405 mm)
    HYRAULIC DISC BRAKES
    FRONT BRAKE : Hydraulic disc
    REAR BRAKE : Drum
    COLOR : Black
    SUSPENSION
    FRONT : Adjustable inverted fork
    REAR : Adjustable piggyback
    Additional Features
    : Durable long lasting engine using Suzuki technology
    : Standard skid plating and fork guards
    : Mikuni carb
    : Aluminum rims
    : Available 18/12" enduro wheel/tire kit
  8. #6
    Join Date
    Mar 2012
    Location
    Woodville, NY
    Posts
    1,339
    Default
    The 250 looks liquid cooled and if its as light as the 200 its probley not bad. Also being a suzuki based motor I wonder if parts interchange.
  9.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
