sprocket shim kits
Results 1 to 9 of 9
Thread: sprocket shim kits
  1. #1
    Join Date
    Sep 2009
    Posts
    1,439
    Default sprocket shim kits
    who sells sprocket shim kits? i want to shim my countershaft and rear sprocket out to clear the tire...thx for any info, rm
  2.
    Advertisement
  3. #2
    Join Date
    Feb 2010
    Posts
    490
    Default
    did you try to offset the wheel? you have clearance on the brake side?
  4. #3
    Join Date
    Apr 2009
    Location
    Western NC
    Posts
    1,003
    Default
    RM a rear wheel sprocket spacer for a LC 4 are about 4mm ,and you can buy them from KTM ,or go to a non-Oring chain and save about an 2mm that's what I got on my Berg with the 5.5 Faba rear and clears the chain with B stone 160/60 003's ,also I have a chain guide from Hugoagogo which is sweet.
    2011 KatoomaBerg FS 570/2011 FS 570 (SOLD) 2010 FE 570 SUMO'ed/2004 KTM 625 SMC(SOLD)
    Suspension by: FastBikeIndustries.com
    HARLEY-DAVIDSON = "The most effective way to convert gasoline into noise without the pesky effects of horsepower"
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    Quote Originally Posted by alarka View Post
    i just installed a set of titanium lifetime guarantee sprockets and an experimental rk super bike chain that isnt even for sale to the public yet, they are letting racer run them then they turn them in to be examined and get a fresh one...im keeping them. i have about 1/8 of an inch between the tire and swing are so everything has to stay where it is...
    do you have a link to the chain guard? thx, rm
  7. #5
    Join Date
    Apr 2009
    Location
    Western NC
    Posts
    1,003
    Default
    http://www.supermotojunkie.com/showt...le-chain-guard + and where did you get the sprockets?
  8. #6
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    thx for the link...
    i got the sprockets here at krouse racing...you need to call often to get through...but he is a good guy...i ordered a 13 front by mistake and he sent me a 14 before i even sent the 13 back....the reg price for the rear is like 179 he did mine for 149 and 89 for the front i think i paid 69...tell him you want the same deal he gave philip in medellin colombia, that i referred you to him.... i bought the titanium II with the lifetime warranty, he said they are working on a lifetime warr chain right now...rm
    http://www.sidewindersprockets.com/contactus.html
  9. #7
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    just sent him a pm to order one, i had to cut my oem to clear the tire...this should help, thx for the info, rm
  10. #8
    Join Date
    Aug 2004
    Location
    Pacific Northwest
    Posts
    9,673
    Default
    plus one on dishing out the wheel.....I have that ktm part number I used for my marchis.. its 2 mm each max I stacked two works well... and i use hugo's deal
    Brian # 30
    KTM 450 SMR
  11. #9
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    Quote Originally Posted by brian View Post
    you have the pn for the counter shat shim washer??? pls hit me up with it if you do, next time i swap the rear tire i want to repaint the rear wheel and shim out the sprockets....
    i was hoping to find a kit, most of the hardware places have crappy stamped washers not a machine grade washer that you know are all the same thikness or close...
  12.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
