Inexpensive Tube Frame Slider Option
Results 1 to 12 of 12
Thread: Inexpensive Tube Frame Slider Option
  1. #1
    Join Date
    Sep 2010
    Location
    Cincinasty
    Posts
    797
    Items for Sale
    Default Inexpensive Tube Frame Slider Option
    So... I was looking for a cheap way to protect my water pump and cases... The thing about big bore thumpers is that... well, they are big motors and combining that with the fact that there is nowhere to bolt a slider on the motor mounts, you have to get creative.
    Let's see if you guys can put 2 and 2 together...
    Fact: 1-1/8" = 1.125"; Lower bar on Baghira & Mastiff measures 1.119" diameter
    Fat bar 1-1/8" risers for dirt bike... Mmmm hmmmmm cheap. If yours are bigger you can shave a bit but these work perfect for me. If your bar is smaller purchase a 7/8" bar riser or use shims.
    Good thing is ths bolt is replaceable in case it gets damaged in a crash...
    Just purchase Delrin sliders from whatever bike... I'm using ones from my girls yzf600r I'm selling... Here are some example pics guys... I've decided how I'm going to rock them but it's pretty versatile what you can do with them...
    I am planning to cut them a little bit to get them to be about a little over 5mm past flush from the w/p and cases... but you get the idea.
    Meeners | KTM 950 SuperMoto | KTM 625 SMC | Genuine Blur 150
  2.
    Advertisement
  3. #2
    Join Date
    May 2012
    Posts
    12
    Default
    That looks like your providing a fixed lateral impact point where there is not supposed to be one for side impact, and a nice long leverage point from the front. I think it would save your case on a mild low side and probably bend your frame on the way to breaking your case with an instance of more violent impact from 90 degree hit. (There's not a lot of clearence left there.)
    In the case of just catching something low hanging while moving forward in a straight line, I think it would definitely tweak the frame. Based on the relatively thin width of the riser and sharp edge...I see a small home made pipe bender. I guess it will depend on if you are going to run them straight out or in the safer raised position.
  4. #3
    Join Date
    Dec 2006
    Location
    just down the hill from 158 corners in 12 miles..cottonwood az...
    Posts
    557
    Default
    straight out is a bad idea....
    tilted up into the case is how i would run them...
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2010
    Location
    victoria, TEXAS
    Posts
    3,426
    Default
    I would think they would rotate upwards if hit from the bottom. So it would probably be safer to run them up against the case to 'maybe' prevent that. Then if course there's the frame bending possibility.
    09 WR250X
    08 SM450R
  7. #5
    Join Date
    Apr 2012
    Location
    Northern California
    Posts
    654
    Default
    I like where your heads at but that just looks way too sketch. For all the reasons everyone else already mentioned. Running them up, already on the case would be the better of the two evils but a decent impact and your sliders will be going through your case or best case they bend your frame.
  8. #6
    Join Date
    May 2007
    Posts
    1,478
    Default
    I think your wasting your time and money. HAve you layed the bike over by hand to see if the cases even hit? Cant think of a single crash iv heard of a bike having road rashed cases the handlebars and pegs keep them away from the ground. Only thing iv seen is like on the DRZ's the shifter breaking the cover but there are protectors for those bikes usually.
    Get some decent peg sliders and bar end sliders and be done, probably cheaper too.
    z
    fund the turbo XRR project
    http://www.supermotojunkie.com/showt...on....-for-now XRR-T Build Thread
    FS: http://www.supermotojunkie.com/showt...ipped-lower-48 A*'s leather jacket!!
  9. #7
    Join Date
    Oct 2010
    Location
    Austin TX
    Posts
    3,030
    Default
    a drop of good quality super glue on the clamp will keep it from rotating on frame -
    ( must be clean )
  10. #8
    Join Date
    Sep 2010
    Location
    Cincinasty
    Posts
    797
    Items for Sale
    Default
    I'm going to be running them tilted up... Sticking out they are just too prone to drag and catch something. And like a lot of you said... They will just rotate up anyway.
    Quote Originally Posted by moto1320 View Post
    Quote Originally Posted by qkenuf4u View Post
    Yep.
    Quote Originally Posted by proz07 View Post
    z
    I already have peg sliders and hand guards... So i guess thats good. If u understood how far this motor and water pump poked out you would understand why I'm making the efforts. Ill check when i get in the garage. These cases and w/p are unfortunately a little more difficult to attain than your normal jap bike :( I'd rather be safe than sorry.
    It's stuff I had laying around so it's not too bad of a financial burden, thankfully. Thanks for the input, Z.
  11. #9
    Join Date
    Apr 2010
    Location
    Cincy, OH
    Posts
    2,457
    Default
    Looks like a good effort Meeners! I would worry about tweaking the frame though. Do they make a skidplate for that bike? Then install the slider off the skidplate? Work will be getting slow for me in the next week so we can build you a skidplate if needed. I still have 3 or 4 feet of 2" dia UHMW stock if you need some more slider material.
    Also Comet tonight?
    07 DRZ 400sm-Daily rider/touring bike
    01 GasGas 280 TXT
  12. #10
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    Quote Originally Posted by GROOVY2 View Post
    ( must be clean )
    until you crash....
  13. #11
    Join Date
    Sep 2010
    Location
    Cincinasty
    Posts
    797
    Items for Sale
    Default
    Quote Originally Posted by FuzzyBock View Post
    Also Comet tonight?
    FK this frame! I ain't skurred... its steel and tube frame. I'm actually more worried about the cases as they are hard to find. They make a skid plate but its' really expensive and extra ugly. They do make one for the xt660 that's sweet. It's expensive too but it's worth it.
    Dude, I'd love to build a skid plate! I might have missed your open time but I'll holler
    I ran them like this to protect the cases...
  14. #12
    Join Date
    Sep 2010
    Location
    Cincinasty
    Posts
    797
    Items for Sale
    Default
    Also Comet tonight?
    FK this frame! I ain't skurred... its steel tube frame. it can bend like gumbi for all i care... I'm actually more worried about the cases as they are hard to find. They make a skid plate but its' really expensive and extra ugly. They do make one for the xt660 that's sweet. It's expensive too but it's worth it.
  15.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
