Oil and your WR250X ???? :)
Page 1 of 2 12 LastLast
Results 1 to 50 of 58
Thread: Oil and your WR250X ???? :)
  1. #1
    Join Date
    Sep 2011
    Location
    Metro Detroit
    Posts
    221
    Default Oil and your WR250X ???? :)
    I'm just curious as you what oil you guys use in yours? How often you change it, what your mileage is certainly?
    I got my bike used with 650ish miles, the oil was changed, looked like clear honey through the glass window. < Good Feeling
    I changed it again at 1000 miles, still looked like it was a mistake changing it again, as is was a golden honey. I changed the filter also at the time.
    At 1990 miles later I changed the oil again and filter. Still looked like dark honey, but wasn't black. The only oil I've ran at this time is AMS Oil 10w40 motorcycle oil.
    Now I'm at almost 3700 miles, longest the bike has gone between oil changes. Roughly 1800 miles on this oil. I know that you can go 3000 miles between changes as manufacture schedules.
    I'm at a cross road, as I've seen the light. I now plan to use something most would frown upon. Got a gallon of Rotella T Triple Protection 15W40. Before you say it's crap, it's 13$ a gallon. Meets JASO MA requirements, low ash, high phosphorus and zinc, just what you need for a motorcycle wet clutch applications. My buddy used it for 13K worth of miles on his 09 Hayabusa with mods with no issue even with a 3k change schedule.
    I ran the 10W40 AMS oil for the winter, as I ride even in the winter. Covers you from -10 to 110degrees. Now that it's summer the 15W40 covers you from 0-110 degrees. My problem lies in the fact you need 2 quarts(or 3 to do, 2 changes), or roughly 1.48 quarts to do the change with filter. I never really planned to run but 1500-2000 miles max on the oil. I like to keep it clean as possible, but not at 12$ a quart. With the Rotella T, you can almost change the oil and filter 3 times, with a price tag of 13$, what a quart of any other syntheic motorcycle oil costs. Pay 11-12$ a quart run it for 3K or roughly 3$ a quart and change it more often, still ahead in my book.
    Lets hear your oppinions on the subject. The good, bad and ugly.
    2010 Wr250X
    FMF FC, FMF Q4, Airbox mod, K&N Filter, Door off, SIM Plug, AIS-EGR removed, ProTaper YZ HI bar, MSR Hand Protectors, Gytr Gold GDO chain, Renthal 13/43, Magnetic Drain Plug, EP Skid plate, R model bottom flaring, Titanium Footpegs, Driven Shifter.
    Setting 3-2-1-4-4-4 55+mpg Fun
  2.
    Advertisement
  3. #2
    Join Date
    Aug 2010
    Location
    victoria, TEXAS
    Posts
    3,426
    Default
    Well, the busa point is invalid. I've got a buddy with almost 50k on his with just regular Suzuki dyno oil. 13k miles isn't really a lot on those. Granted 50 is crazy high.
    I use elf full synthetic champione in my x. Or at least I did until my shop can't get it. Now I use Suzuki synthetic. Bike has somewhere around 9k miles. I change it anywhere from 1500-2500. And I don't thing you can ride it much harder than I do...
    Oil always relatively clean when it comes out.
    09 WR250X
    08 SM450R
  4. #3
    Join Date
    Feb 2012
    Location
    Hawaii
    Posts
    1,237
    Default
    I use Rotella T6 5W-40.
    I thought our bikes take 1.4L with a filter change. Why are you filling 1.48L in there?
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    Yamaha says you can go 3000 miles between oil changes and 6000 miles between filter changes.
    Unless you are doing something really bizarre and harmful to the bike to begin with, or using really cheap-o oil I see no reason to change the oil any more frequently than Yamaha recommends.
    I do change my filter with every oil change though.
    I use Amsoil synthetic. I pay a high price per quart for motorcycle specific oil so I can ride the bike more than work on the bike. I easily go anywhere from 2800-3200 miles between oil and filter changes.
    The wr250x is not a Husky, Aprilia, or KTM. It does not require that kind of maintenance.
    2008 WR250X
    Gearing: 13t - 48t
    PC-V - Air Box Door Removed
    FmF Q4 Slip-on - BT-003rs
  7. #5
    Join Date
    Jul 2008
    Location
    Central New York
    Posts
    1,189
    Default
    50k is nothing for a busa those motors are so big and run a low rpm in most cases because of it they should run 150k easy without needing to be toughted for the most part.
    i change mine every 1500-2000 with full synethic amsoil, mines always black but even right after a change it turns black again. these motors will run on almost anything there simply bulletproof. they do turn high rpms in many cases tho so i wouldnt go over 2k for changing um tho.
  8. #6
    Join Date
    Jun 2008
    Posts
    1,485
    Default
    Amzoil every 3k with new filter... I thought about shorter intervals but that's why I pay for Amzoil, its supposed to be good to 7k so it better be good at half the interval.
    "Losing a race is no reason to cry, son. The fact that Daddy doesn't like you anymore is a pretty good reason though." (Quote from Avatar)
  9. #7
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    Quote Originally Posted by phonebem2 View Post
    Amzoil every 3k with new filter... I thought about shorter intervals but that's why I pay for Amzoil, its supposed to be good to 7k so it better be good at half the interva.
    Bingo.
    And if I go to 3500-4000 miles "by accident", I don't sweat it one bit.
    2008 WR250X
    Gearing: 13t - 48t
  10. #8
    Join Date
    May 2011
    Location
    Tucson, AZ
    Posts
    164
    Default
    Mark me down for another Amsoil user. Factory intervals (3k) are good enough for me. I also do filter changes each time.
    I track mine too.
    2011 WR250X with some mods.
  11. #9
    Join Date
    Sep 2011
    Location
    Metro Detroit
    Posts
    221
    Default
    Quote Originally Posted by pineapplebrah View Post
    quarts < liters damn metric system people
    1.4L = 1.48 Quarts "that was a joke" /\
    1 Rotella syn
    1 Other
    5 AMS Oil
    7 Syntheic
    I've got a gallon of it, will only run it 1500 -2000 miles max. The filters, I will change every other change. I will take it out and spray it in the opposite direction of oil flow from 5-7" away, to clean it before reinstall. With good old Brakleen, yeah boy.
    I'll let you guys know what I think of the oil compared to AMS oil.
    2010 Wr250X
  12. #10
    Join Date
    Feb 2012
    Location
    Hawaii
    Posts
    1,237
    Default
    Quote Originally Posted by DdogWr250X View Post
    Thanks for pointing that out. I read it too fast.
  13. #11
    Join Date
    Mar 2012
    Posts
    13
    Default sad really ddog
    You have a lil baby on way and this is more important wow you will get yours daddy
  14. #12
    Join Date
    Jul 2008
    Location
    Central New York
    Posts
    1,189
    Default
    ^^ where the hell did that come from.
  15. #13
    Join Date
    Mar 2012
    Posts
    13
    Default haha
    His gf that is pregnant and this bs is more important!!!!! YOUR GONNA BE A DADDY YOU FOOL!!!!!!!!!!!!!!!!! YOU WOULDNT HAVE THAT BIKE IF I WOULDN'T HAVE FOUND IT FOR YOU AFTER OTHER WAS STOLEN!! YOU LOOKED FOREVER BUT NO I FOUND THE BIKE!!! MAYBE GOD WILL BLESS ME AND SOMEONE WILL STEAL THIS ONE TOO MAYBE YOU WILL STRAIGHTEN UP!!! You wanna play with me all your lil friends on here are gonna know what your doing!! who walks out on there pregnant gf for a motorcycle forum are you joking!!!! Its gonna be your first born and this is the respect i get!!! yeah right for all you reading this i am his CRAZY PREGNANT GF WHO IS MADDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
  16. #14
    Join Date
    Aug 2010
    Location
    victoria, TEXAS
    Posts
    3,426
    Default
    Wow..
    09 WR250X
    08 SM450R
  17. #15
    Join Date
    Feb 2012
    Posts
    27
    Default
    Quote Originally Posted by rk2001 View Post
    Gotta love them crazy bitches
  18. #16
    Join Date
    Jul 2010
    Location
    Flintstone, Maryland, United States
    Posts
    561
    Default
    this just got WEIRD
  19. #17
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    2008 WR250X
    Gearing: 13t - 48t
  20. #18
    Join Date
    Apr 2011
    Location
    757
    Posts
    132
    Default
    BEST
    THREAD
    EVER
    sidenote* Motul 5100 semi-synt on all my race bikes every other track day or every race weekend.
    This little guy uses 1.5 qts...its so cheap, why not change often.
    CCS EX #23
    ASRA #231
    AMA #231
  21. #19
    Join Date
    Sep 2010
    Posts
    500
    Default
    ^^^ oww snap!
    GF is trolling and pissed lol iv never seen this before.
    Ive been running mobil one racing 4t. bike seems to like it but i wanna switch to a cheaper oil like rotella. Waiting to hear some feedback before i buy a gallon of that. If the bike doesnt mind i dont see the point in spending 10 bucks a quart for mobil one.
  22. #20
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    More than a few people here swear by Rotella. <-- clicky
    I don't think there's much risk to using it at all.
    2008 WR250X
    Gearing: 13t - 48t
  23. #21
    Join Date
    Jul 2008
    Location
    Central New York
    Posts
    1,189
    Default
    you summed it right up there lol. take it elsewhere noone here cares about your crazy ass hormones or your personal life.
  24. #22
    Join Date
    Aug 2010
    Location
    victoria, TEXAS
    Posts
    3,426
    Default
    Supermoto > crazy lady
    09 WR250X
    08 SM450R
  25. #23
    Join Date
    Apr 2011
    Location
    757
    Posts
    132
    Default
    Quote Originally Posted by WRsteveX View Post
    buahahahaha
    CCS EX #23
    ASRA #231
    AMA #231
  26. #24
    Join Date
    Apr 2011
    Posts
    209
    Default
    Im sure she's fine now....
    2004 WR450
  27. #25
    Join Date
    Feb 2012
    Location
    Hawaii
    Posts
    1,237
    Default
    Bitches be crazy.
  28. #26
    Join Date
    Jun 2008
    Posts
    1,485
    Default
    Wow, I thought things were going to get all Maury Povich there for a minute!
  29. #27
    Join Date
    Mar 2012
    Posts
    13
    Default lol
    sorry guys hormones are raging lol glad i got that off chest have fun wont bother yous again i got the point across and things are just fine!!!!!
  30. #28
    Join Date
    Jul 2010
    Location
    Posts
    561
    Default
    bye
  31. #29
    Join Date
    Jan 2012
    Location
    Springfield, MO
    Posts
    326
    Default
    I use yamalube in mine. I forgot which wt. it was..
    '09 WR310x (Street Tard/stunt)
    '02 Yz 125 (Dirt)
    Check out my Youtube!
    http://www.youtube.com/user/Bulletsrain?feature=moby
  32. #30
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    I think I liked you better the other way........
    2008 WR250X
    Gearing: 13t - 48t
  33. #31
    Join Date
    Mar 2012
    Posts
    13
    Default lol
    yeah im sure it was quite amusing when you all seen that lol For the record i also ride just haven't bought my bike yet because i am preg and cant ride this year!!!! but i will be getting the bike by end of summer to ride next yr !!!! for the record i really don't want his bike stolen because i love it to much lol and then i wouldn't have someone to ride with!!! I am sorry babe for that!!!!
  34. #32
    Join Date
    Apr 2011
    Posts
    209
    Default
    I know from experience.... All pregnant women are crazy.
    2004 WR450
  35. #33
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    Only some decent pics can prove you are who you say you are....
    2008 WR250X
    Gearing: 13t - 48t
  36. #34
    Join Date
    Oct 2009
    Location
    Bham, AL
    Posts
    49
    Default
    Wow this is awesome!
    Don't have a WR but I ran Motul 300V and 5100 in my DRZ-SM and liked it alot. DRZ stators will commit suicide if you don't use good oil...
    09 DRZ400SM - 3x3, JD Jetting, MRD SSW, BajaDesigns 8in RaceLight, Edge2, ProBends, knobbies...
  37. #35
    Join Date
    Jan 2012
    Location
    Hudson Valley NY
    Posts
    40
    Default
    Quote Originally Posted by Mtsmith View Post
    Really? The stator?
  38. #36
    Join Date
    Aug 2006
    Posts
    40
    Default
    i run mobil one 4T in my wrx change it every3k or so with a new filter, wix or kn usually.
    i put rotella in the ttr no problems and it cheap.
    08 wrx
    14/49, bt003s, fmf slip on, pc3,
  39. #37
    Join Date
    Jul 2008
    Location
    Central New York
    Posts
    1,189
    Default
    Quote Originally Posted by chris07r6 View Post
    haha +1 to that, been there but it gets worse when they have 2 and have to take care of 2 all the time and (Do Everything Themselves) as if they get no help when they actually get a lot of it. were Men were not Women and we never will be so we are never gonna do all that you do and nor should we lol.
    Quote Originally Posted by Grendel336 View Post
    ^^haha
  40. #38
    Join Date
    Aug 2010
    Location
    victoria, TEXAS
    Posts
    3,426
    Default
    Is this really true? I've never heard this. Always known drz's to run on just about anything. Hell the manual only recommends 87 octane fuel.
    09 WR250X
    08 SM450R
  41. #39
    Join Date
    Apr 2011
    Posts
    209
    Default
    Quote Originally Posted by Stubbz View Post
    ^^haha
    I have two girls 4 and 1 and this man speaks truth
    2004 WR450
  42. #40
    Join Date
    Jun 2008
    Location
    Delaware - USA
    Posts
    1,135
    Default
    I still want pics of the psycho-bitch!!!!!!!!!
    2008 WR250X
    Gearing: 13t - 48t
  43. #41
    Join Date
    Feb 2012
    Location
    Hawaii
    Posts
    1,237
    Default
    Here you go.
  44. #42
    Join Date
    Mar 2012
    Posts
    13
    Default Lay off
    Please lay off the Bitch word i said i was crazy not a Bitch!!!!
  45. #43
    Join Date
    Mar 2012
    Posts
    13
    Default lmao
    Here you go.
    WAY OFF IM A HOT CRAZY GF!!!! Lets get that straight right now!!!!!!!!
  46. #44
    Join Date
    Sep 2011
    Location
    Metro Detroit
    Posts
    221
    Default
    I got some cheap oil that is good, so that I can spend more money. On Diapers and modding my baby, once I found out what sex it is. I then will know what turbo kit to buy. Got to know what size flange you need, boys and girls are different.
    This is my woman, she is crazy, but a perfect fit, for me. She does put up with my shit, I've been told that "I'm a asshole" but I don't believe it.
    2010 Wr250X
  47. #45
    Join Date
    Jul 2008
    Location
    Central New York
    Posts
    1,189
    Default
    hahaha wow she's gonna love seeing that posted on the site lol. unless the baby is here theres no reason for you to be at her hip doing whatever it is she wants you to do, you'll have plenty of that after the baby comes, if you dont know the sex yet she's barely pregnant lol so not like shes 8 months huge and givin ya shit cuz your not helpin her. they can do everything pregnant they can not pregnant trust me been there multiple times, some just cant handle it.
  48. #46
    Join Date
    Apr 2011
    Location
    757
    Posts
    132
    Default
    this just gets better every time I check in on it
    CCS EX #23
    ASRA #231
    AMA #231
  49. #47
    Join Date
    Jun 2008
    Posts
    1,485
    Default
    Quote Originally Posted by rc23 View Post
    Yeah, things did take an interesting tangent... Now give me some of that popcorn!
  50. #48
    Join Date
    Oct 2011
    Location
    In the weeds
    Posts
    492
    Default
    Oh yeah it's true. Make sure you check the turn signal fluid too, or else the exhaust will freeze up.
    2010 Yamaha WR250X SOLD
    2011 Triumph Speed Triple SE SOLD
    2012 Yamaha WR450F
    2014 Yamaha FZ09
  51. #49
    Join Date
    Oct 2011
    Location
    In the weeds
    Posts
    492
    Default
    You obviously didn't read your post then.
    2012 Yamaha WR450F
    2014 Yamaha FZ09
  52. #50
    Join Date
    Aug 2010
    Location
    victoria, TEXAS
    Posts
    3,426
    Default
    Quote Originally Posted by organ donor View Post
    thats what i was thinking..
    09 WR250X
    08 SM450R
  53.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
