Results 1 to 15 of 15
Thread: CRF150F throttle tube options?
  1. #1
    Join Date
    Jun 2010
    Location
    Monroe, NY
    Posts
    19
    Default CRF150F throttle tube options?
    Did a bunch of searching this morning and came up empty.
    Looking to get a 1/4 turn throttle (or close to it) setup for my 150F SM bike. The stock setup just isn't cutting it and it's putting a hurtin' on my wrist.
    Anyone know of an aftermarket or other OEM application that'll work?
    Thanks,
    -DM
  2. #2
    Join Date
    Jul 2007
    Location
    New Jersey
    Posts
    215
    Default
    THIS ONE should work for you, it's made for 7/8" handlebars.
  3. #3
    Join Date
    Dec 2006
    Posts
    211
    Default
    Don't use that. It is made for a pitbike, probably 1/4 turn on a 20mm carb. Buy a CR85 Throttle and Pro Taper Aluminum throttle tube. I run one on my PWK28 and it is very little turn to WOT. This is obviously for if you are not running an accelerator pump carb, if you have one just get a CRF150R throttle and matching tube.
  4. #4
    Join Date
    Aug 2009
    Location
    Gulfport, MS
    Posts
    303
    Default
    I've got the one linked on my 100 with a 24mm carb. It works fine.
  5. #5
    Join Date
    Jun 2010
    Location
    Monroe, NY
    Posts
    19
    Default
    Thanks for the info guys, I'll look into both options. I used to have a few pit bikes, might even have one of those tubes laying around somewhere.
  6. #6
    Join Date
    Nov 2010
    Posts
    18
    Default
    Give me another day or two. G2 Ergonomics helped me find a quarter turn throttle setup for my Ducati SS 1000 race bike. That thing had a long draw, slightly more than half a turn. He set me up with a two stroke single cable setup that wasn't too expensive and definitely did the trick.
    I sent a note to them yesterday. They usually get right back in touch with me. I'll let you know.
  7. #7
    Join Date
    Nov 2010
    Posts
    18
    Default
    G2 got back to me, they said to mess around with the throttle I have on my Ducati. He said the two variables are size of cable and amount of pull. He said if we can get cable to fit, we should be able to find a cog that will give the right amount of pull.
    If you want to reach out directly my contact is Gary Gibbs, gary@g2ergo.com, tell him Dave Z sent you over regarding a CRF150F, I'm going to play around over the weekend with the system I have.
  8. #8
    Join Date
    Nov 2010
    Posts
    18
    Default
    Finally got into the garage and pulled my G2 Ergonomics quick turn throttle off my Ducati race bike and mounted it on the CRF150F. I have the largest cog setup for this bike. I think the pull is a little too short. It makes the bike into like a 1/8 turn throttle. I'm going to give my feedback to G2 and order one size cog smaller which should make the pull between 1/8 and 1/4. G2 makes a great product, I've used other brands on my race bike but they all my throttle cable rubbing rubbing on metal, which meant they would break at the worst possible time. G2 has a plastic bushing that makes sure the action is smooth.
  9. #9
    Join Date
    Nov 2005
    Location
    Connecticut
    Posts
    173
    Default
    This might work for the 150F ???
    Magura Model 314
    http://www.pingelonline.com/magura_throttle.htm
    Or .... , Maybe one of these ??
    http://www.motionpro.com/motorcycle/...ottle_sleeves/
  10. #10
    Join Date
    Jul 2011
    Posts
    7
    Default
    I built up an epoxy ramp on the throttle tube (under the cable) that shortened the pull. It works, pretty cheap too.
  11. #11
    Join Date
    Jan 2009
    Posts
    63
    Default
    I had motion fit a cable to their Vortex Throttle Tube. I had to send my throttle to them so the could get the correct specs to build the cable to fit. But I would guess they kept the info so hopefully you wont have to send yours in again.
    Its the GREATEST! The throttle before was almost unusable, having to regrip twice to get to wfo.
    Heres the throttle tube- http://www.motionpro.com/motorcycle/partno/01-0054/
    CCS EX #13
    GSXR600--Husky 510SM--CRF150f Play
  12. #12
    Join Date
    Feb 2010
    Posts
    426
    Default
    Nice!
    Motion Pro can definitely help with this if you just give them a call. I just set up my CRF230F with a Motion Pro revolver (adjustable) and custom throttle cables. I get to ride it for the first time today - hopefully my chicken wing days are behind me.
    AMA-D36 #314x
    SMUSA #314
    Norcal Motorsports http://www.norcalktm.com/
    Motion Pro http://www.motionpro.com/
    Malcolm Smith Motorsports Foundation http://malcolmsmithmotorsportsfoundation.org/
  13. #13
    Join Date
    Jan 2007
    Location
    Staten Island, NY
    Posts
    815
    Default
    Quote Originally Posted by dmyers_427 View Post
    dmyers what did you end up doing to get quick throttle on the 150f??? I'm at a total loss w/ this thing. I bought the motion pro vortex thing and the 230f throttle cable to fit it but the cable can't be removed from the 150f carb top!
    with the exception of your reply and all my research, i think I'm going to have to build up the channel the cable rides in on the throttle tube cam like other people have, with epoxy or something similar. maybe that black stuff that goes into a screen window channel - to hold the screen in - glued in the throttle cable groove...
    CRF150R sumo'd - CR85 road racer - CRF150f sumo'd - CRF250f Sumo - YZF450 Sumo
    '82V45 Sabre '00 Aprilia SR50, 82 Yamaha XJ650RJ Seca, '72 RD350 R5
    KTM SX250, RM250, ESMRA, NJMINIGP, NEMM, OVRP
    520 EXC Tard - SOLD, 525 SMR - SOLD, DRZ400SM - SOLD, tons of 80's and 125's as a lad
    http://www.youtube.com/watch_popup?v=xdj67XknFrM#t=5
  14. #14
    Join Date
    Jun 2010
    Location
    Monroe, NY
    Posts
    19
    Default
    I just ended up leaving it alone and riding with my right elbow a little high, haha
    I couldn't come up with anything good enough for me to be confident with, so I just left it be.
    Building it up the way your suggesting is probably fine.
    Hope your neck is doing well.
    '07 KTM 144sx #427
    '06 Honda CRF150F Sumo #427
  15. #15
    Join Date
    Jan 2007
    Location
    Staten Island, NY
    Posts
    815
    Default
    finally got it sorted out. When you order the stock honda throttle cable for the 150f you have to snap the cable in the carb top, so it comes separated! So now you have the carb top to use w/ the 230 cable and that motion pro vortex quick throttle. Ran this setup last weekend in a 4hr endurance and it's So much better.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
