DRZ400SM List of MUST DO modifications and "FIXES"
Results 1 to 18 of 18
Thread: DRZ400SM List of MUST DO modifications and "FIXES"
  1. #1
    Join Date
    Feb 2011
    Location
    California, USA
    Posts
    112
    Default DRZ400SM List of MUST DO modifications and "FIXES"
    This seems like a good idea to me; Start a list of "MUST DO" mods or "fixes" for the DRZ400. I am a new owner and I have spent hours searching through all the threads for the most common or "must do" mods for the DRZ400SM. Hopefully this list will help future owners or current owners that haven't come across the information.
    List of MUST DO mods or FIXES for the DRZ400:
    001. Counter Shaft Sprocket "Loctite Fix" http://www.thumpertalk.com/forum/arc.../t-625998.html
    002. The 3X3 Mod + Jet Kit http://www.thumpertalk.com/forum/arc.../t-378193.html
    003. Oil changes at 1500 miles (not 3000 miles as I always do) http://www.thumpertalk.com/forum/arc.../t-812702.html
    Thumpertalk.com oil change walk through http://www.thumpertalk.com/forum/arc.../t-665513.html
    004. Starter + stator locktite fix http://www.drzparts.com/2010/05/dr-z...h-loctite-fix/
    005. MCCT and primary nut fix http://www.youtube.com/watch?v=dVPbkz3aXR8 Thumpertalk.com article http://www.thumpertalk.com/forum/arc.../t-639008.html
    006.
    Last edited by CN08DRZ400SM; 02-25-2011 at 08:27 AM. Reason: additional item for list
  2.
    Advertisement
  3. #2
    Join Date
    Apr 2009
    Location
    British Columbia Canada
    Posts
    189
    Default
    ditching the stock taillight should be somewhere on the list too
  4. #3
    Join Date
    Feb 2011
    Location
    California, USA
    Posts
    112
    Default
    Quote Originally Posted by pinefresh View Post
    Thanks for the link (another one I didn't know about) and I added it to the list (004).
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Sep 2010
    Posts
    131
    Default
    The 3x3 mod is a bad thing if you don't re jet the bike. It'll make the already lean mixture even more lean, so it's always 3x3 + jet kit...
  7. #5
    Join Date
    Jul 2010
    Location
    Victoria, BC
    Posts
    5
    Default
    MCCT and the primary nut fix. Only two i dont have done
  8. #6
    Join Date
    Feb 2011
    Location
    California, USA
    Posts
    112
    Default
    Quote Originally Posted by Vicliner View Post
    Do you have a link to procedures for MCCT (what is MCCT?) and the primary nut fix?
  9. #7
    Join Date
    Jun 2010
    Location
    idaho
    Posts
    190
    Default
    Quote Originally Posted by CN08DRZ400SM View Post
    manual cam chain tensioner, as the stock automatic one puts a lot of stress on the cam chain and pre maturly wears it out. and the primary nut is a nut on the end of the right side of the crank shaft
    05 DRZsm
  10. #8
    Join Date
    Apr 2009
    Location
    Posts
    189
    Default
    Here's a video for installation.
    When I did mine I was able to do it without removing the exhaust or the black vapour reclamation thing.
  11. #9
    Join Date
    Jul 2010
    Location
    Victoria, BC
    Posts
    5
    Default
    Probably going to get slagged for this, but everything you've mentioned above, is in the FAQ'S at this site.
    http://www.thumpertalk.com/forum/forumdisplay.php?f=397
    And the drzparts.com references most likely have been taken from the above site as well.
    The MCCT youtube movie quoted above is not the most recommended way of doing that fix, albeit prolly the most common way. Best to take valve cover off and establish TDC. Again, everything is in the FAQ'S.
    hope i didnt break any forum rules.
  12. #10
    Join Date
    Oct 2006
    Location
    Orchard Park, NY
    Posts
    796
    Default
    +1
    I was about to post the same thing. The TT DRZ FAQ is a comprehensive reference.
    '03 drz400E converted to sm
    '12 Triumph Street Triple-R
    '97 zx6r track beater
  13. #11
    Join Date
    Feb 2011
    Location
    California, USA
    Posts
    112
    Default
    Thanks for the additional info on the MCCT fix "Best to take valve cover off and establish TDC."
    I am sure with enough time and plenty of searching we can all find all the articles that we would ever need, but I thought it would be a good idea to make a list of all the mods and fixes in one single page. If you stick around you might end up reading an article you haven't read in the FAQ's.
    2005 KTM 625 SMC http://www.supermotojunkie.com/showt...05-ktm-625-smc
    1981 Yamaha Virago - Cafe Fighter Project
    2006 Kawasaki Ninja 636 - SOLD
    2008 Suzuki DRZ400SM - SOLD
  14. #12
    Join Date
    Jul 2010
    Location
    Victoria, BC
    Posts
    5
    Default
    Doing hours of research as you have done, above and beyond all the posted FAQ's, will pay off when you do the fixes. I've done most of them along with some of the other small issues and the extra research will really help you with things "not to do."
    But,
    I dont know if you have done this or not yet. Look at the 3 pages in the link I posted. Along with all the extra research you already did, you will have have everything done before long.
    Putting it all together in this forum would probably be a good idea as well if it hasnt been done yet.
    Sorry for all the jibberish, been up all night with a screaming baby. Ill leave this thread and let you do your thing.
  15. #13
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    I've had TWO nuts/countershafts crack off on me. Second one landed me overnight in the hospital. lesson learned: USE THE STOCK RUBBERIZED CS SPROCKETS! the other one vibe until they end up breaking the nut off.
    original fix which has worked for a year now: http://socalsupermoto.com/blog/2011/...ntershaft-fix/
  16. #14
    Join Date
    Mar 2013
    Location
    North Jersey
    Posts
    278
    Default
    Figured I would bump this thread instead of starting a new one. Do you guys recommend all of these "fixes" on the '13 DRZ as well? I just stumbled upon it and now it's got me nervous...
    Adrenaline's a hell of a drug
    Riding Game Challenge: 2
  17. #15
    Join Date
    Apr 2012
    Location
    SATX
    Posts
    125
    Default
    Countershaft sprocket locktite fix is mandatory. Research the others on the thumpertalk DRZ400 FAQ and decide whether or not you want to do them.
  18. #16
    Join Date
    Mar 2013
    Location
    North Jersey
    Posts
    278
    Default
    Yeah, it looks like I have a long night a head of me... Definitely doing these.
  19. #17
    Join Date
    Nov 2015
    Location
    England
    Posts
    2
    Default VIDEO - Suzuki DRZ400S Modifications
    Here's my DRZ VIDEO - Dual Sport Modifications for Adventure Motorcycling - ENJOY
  20. #18
    Join Date
    Nov 2015
    Location
    England
    Posts
    2
    Default
    Here's another of my videos:-
    Idiots Guide to Adventure Motorcycling
    ENJOY
  21.
    Advertisement
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
