Differences between DRZ-400 SM, S, & E models.
Results 1 to 4 of 4
Thread: Differences between DRZ-400 SM, S, & E models.
  1. #1
    Join Date
    Apr 2009
    Location
    Austin, TX
    Posts
    885
    Default Differences between DRZ-400 SM, S, & E models.
    I wanted to start a thread on this so that it is easy to access if there are any questions about the differences between the 3 and what parts match and which do not. From what I have learned these are some of the differences and correct me if I am wrong.
    Swing arms
    -Bolt up on all 3 models
    -S and E models do not have a chain guide like the SM models do
    -SM has different caliper mounting than S & E
    Subframe
    -S & SM models are the same (have mounts for fender/racks and are longer)
    -E model is like the S & SM but shorter (no mounts for fender/rack)
    -All 3 will bolt up to any 400 frame
    Rear Brake lever
    -S & SM Models have a tab for a brake switch
    -E Models have no tab for a brake switch
    -All 3 will bolt to any 400 frame
    Engine
    -E models
    -12.2:1 Compression
    -Stage 2 cams
    -Larger Carb
    -S & SM
    -11.3:1
    -Stock Cams
    -Smaller Carb
    Suspention
    -SM has different size triple clamps, larger inverted forks, stiffer rear spring
    -S & E have same size triple clamps, smaller forks, softer rear spring
    This is all I can think of right now and need to get going so correct me if I am worng and please ad any other info you know.
  2.
    Advertisement
  3. #2
    Join Date
    Feb 2008
    Location
    Tulsa, OK
    Posts
    1,659
    Default
    Not all E models have the FCR carb. Someone else will chime in but at some point they quit selling the E with the FCR...
    Also the E rear caliper will not work on the SM swingarm. The rear calipers have specific mounts on the swingarm and the E mounts differently than the SM.
    KTM 450 SMR
  4. #3
    Join Date
    Apr 2009
    Location
    Austin, TX
    Posts
    885
    Default
    Quote Originally Posted by DMCCOY View Post
    not all E models have the FCR carb. Someone else will chime in but at some point they quit selling the E with the FCR...
    Cool we will see what we can come up with. Original post will probably be edited many times.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2004
    Posts
    1,465
    Default
    there are 50 state E models and 49 state E models. 04-07 california E models are 50 state. 00-06 the rest of the country got 49 state E models. california had 49 state E models 00-03. 07 was the last production year for the E in the US and they were all 50 state.
    49 state E models have E cams (maked A/B) ,not stage 2.
    49 state E models have the fcr carb and single layer base gasket (.010") and 10,500 rpm rev limit.
    50 state E,S and SM have the 36mm mikuni bsr carb,milder cams (marked D/E) and 3 layer base gasket (.030") and 10,000 rpm rev limit.
    there are more differences and changes thru the model years.
    Eddie Sisneros
    Epic Motosports/Sisneros Speed Works 303-485-1858 SSpeedWorks@gmail.com
  7.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
