Cheap, but good chain breaker?
Results 1 to 19 of 19
Thread: Cheap, but good chain breaker?
  1. #1
    Join Date
    Aug 2009
    Location
    Asheville, NC.
    Posts
    2,902
    Default Cheap, but good chain breaker?
    Looking to buy a chain breaker. But I don't wanna buy a $100 chain breaker. I need one that rivets too.
    My watches have springs and gears and my vehicles burn gasoline.
  2.
    Advertisement
  3. #2
    Join Date
    Jan 2010
    Location
    San Mateo, CA
    Posts
    1,444
    Default
    I might be wrong but I believe the one from Harbor Freight is not too bad.
    Lewis a.k.a. Frenchie a.k.a. Hey You!
    YZ85 '05 - Why do I ride minis? Because I don't need to compensate for anything!
    RMZ250 '07 - Engine exploded (twice!)
    450SMR '06 - OMAGAD! OMAGAD! OMAGAD!
    SMUSA #666
  4. #3
    Join Date
    Apr 2007
    Posts
    287
    Default
    Harbor freight one works great i have one but does not rivit But otherwise works great and i got mine for $2.50 gotta love those coupons in every mag these days
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2009
    Location
    Prince George, VA
    Posts
    249
    Default
    I have owned a few cheap ones but they all broke the pins. Bought the $89 DID one and it is rock solid. The motion pro one works great too but it is again close to $100. I really believe this is one of those cases where you do actually get what you pay for.
    http://i49.photobucket.com/albums/f2...ker_Banner.jpg
    2005 DRZ435SM
    2004 SV650
    1985 atc250sx (3 of them)
    1985 atc200x
  7. #5
    Join Date
    Apr 2007
    Posts
    287
    Default
    You know i usually agree that it is a get what you pay for thing but the harbor freight one has held up to several chains at least 10 or varying size for 428-530 so i have do disagree on this one the thing is probably made from pot metal smelted by a 4 year old Chinese kid but is works. Its not pretty its heavy and ugly and covered in grease when you get it but it works here is a link of there shoe model and is 12 bucks new so break 7 of them to one did anyway here it is
    http://www.harborfreight.com/heavy-d...ker-66488.html
  8. #6
    Join Date
    Jul 2006
    Posts
    444
    Default
    Also another thumbs up for the DID tool. I ordered one because my ducati dealer couldn't get me in for two weeks to do my 520 conversion kit. What I saved on the dealer visit more than paid for the DID tool and it worked perfectly. I looked at the motion pro unit and the one Cycle Gear sells too and the DID is built way better.
  9. #7
    Join Date
    Aug 2009
    Location
    Prince George, VA
    Posts
    249
    Default
    Quote Originally Posted by Minimoto7 View Post
    That tool does not rivet the chain. The pins break when you rivet the new master link.
    2005 DRZ435SM
    2004 SV650
    1985 atc200x
  10. #8
    Join Date
    Jul 2010
    Posts
    150
    Default
    I just purchased the Stockton Tool co. chain press/breaker/riveter new on Ebay for 39.99 + shipping. Cycle gear sells it for $89.99. I haven't broken or riveted chain with it yet but I will be doing it on my GSXR very soon. I'll let you know how it works.
    Fast is smooth. Smooth is Fast.
  11. #9
    Join Date
    Aug 2009
    Location
    Asheville, NC.
    Posts
    2,902
    Default
    Quote Originally Posted by screwtape View Post
    I seen that one at cycle gear the other day. It's hard to pull the trigger on some things for me. Like a $90 chain breaker. I know it's needed but dang. $90? For real?
    I will have to look on fleabay. If I cant find anything, HF cheap-o it is.
  12. #10
    Join Date
    Jul 2006
    Location
    Escondido, CA
    Posts
    2,055
    Items for Sale
    Default
    I have a Motion Pro and never had any problems. It was a gift from a customer because I sold a bike for him. Before that I used a Makita die grinder and carefully ground the riveted head off and used punch to then knock it out. Not the best method, but I too didn't want to spend the price for chain breaker. It reminds me of using PVC pipe to install forks seals. It can be done that way, but if you need to do it alot, the correct tool will pay for itself. FYI, I think I'll try a HF and put it in with track tools. Can't beat that price. Good luck
    Team Damn Dummy Racing #607 SEAN
    DDR "Making the poor man fast"
    SMX Racing -Southern Ca. Supermoto Race Series
  13. #11
    Join Date
    Dec 2008
    Location
    Silver Spring, MD
    Posts
    1,393
    Default
    Sorry, but you'll break pins in most kits trying to break a chain with the tool itself. The cheapest, easiest, most reliable way to break a chain is with a dremel, either by grinding down the rivet heads on one side and pressing them out, like if it's a new chain you need to shorten, or by simply cutting each wall of a link with a cut off wheel on a worn chain you are removing.
    Remembering #93 Stacy Summers, 1972--2011
    sweat, don't bleed.
    --rrp
  14. #12
    Join Date
    Oct 2009
    Location
    Ireland
    Posts
    523
    Default
    i use two tools to change a chain:
    A big angle grinder
    An even bigger hammer
  15. #13
    Join Date
    Apr 2007
    Posts
    287
    Default
    Quote Originally Posted by Orangeshirtdude View Post
    Got to agree grind the pins down first or any tool would eventually break and i know the harbor freight one doesn't rivet but my local shop rivet the ones i need down for $5 i just put in a regular link until i can get one riveted.
  16. #14
    Join Date
    Jul 2010
    Posts
    150
    Default
    I riveted the RK 520 chain on my GSXR today using the Stockton tool and it worked flawlessly! I have never used a chain tool before but it was super easy. The link press works great on it as well and I don't know what I would have done without it. I did not however use it to break chain because im lazy so I used bolt cutters... As long as you grind down the rivet on the pin before you push it out its not going to be a problem anyway. Definitely worth the $!
  17. #15
    Join Date
    Nov 2010
    Location
    Lansing, MI
    Posts
    364
    Default
    I've used the motion pro press and the rivit tool. Both of which have failed after a couple of uses, although I did learn on them.
    The HF one I have in all honesty has held up much better.
    04 crf450r (currently being parted out)
  18. #16
    Join Date
    May 2007
    Location
    Balls Deep
    Posts
    3,797
    Default
    I riveted the RK 520 chain on my GSXR today using the Stockton tool and it worked flawlessly! Definitely worth the $!
    On sale here... http://www.cyclegear.com/spgm.cfm?L1...em=PRC_L35-247
    2007 RXV550SM/2007 KTM 690SM
    NO REMORSE / NO REGRET Previous Supermotos: 2008 SM510R
  19. #17
    Join Date
    Jul 2010
    Posts
    150
    Default
    Quote Originally Posted by exit90a View Post
    Yup, thats the one! Don't let cyclegear rip you off though, get it on ebay for waaay less!
  20. #18
    Join Date
    Nov 2010
    Posts
    128
    Default
    The DRC kit is the same quality, if not better then the $100 RK/Motion Pro kits and sells for about $60. You can get it at Wheeling Cycle Supply. I riveted 4 chains before breaking a pin, which is about $3 to replace.
  21. #19
    Join Date
    Oct 2007
    Location
    Seattle
    Posts
    891
    Default
    Pit Posse tool works good for riveting but you have to follow directions closely. I also use dremel and a punch to remove links.
    Dmitry
  22.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
