Spark plugs: resistor vs non resistor
Results 1 to 6 of 6
Thread: Spark plugs: resistor vs non resistor
  1. #1
    Join Date
    Aug 2004
    Location
    Utah
    Posts
    2,684
    Default Spark plugs: resistor vs non resistor
    Is there a problem if I use a resistor type plug in a non resistor application?
    My bike calls for a D8EA or CR9EK. But I have some Splitfires that will interchange with the DR8EA, which I think is the same as the D8EA except resistor, right?
    Any ideas on issues or problems with my idea to use the Splitfire? A mechanice friend told me not a good idea. So what should I use then?
    2001 Yamaha TTR-150L
    2005 CRF450X
    1998 Buell White Lightning
  2.
    Advertisement
  3. #2
    Join Date
    Nov 2005
    Location
    bucks county, PA
    Posts
    987
    Default
    I ran shitfires in a car once, and they are junk. stick with the ngk plugs. the EK plug is really nice. have one in my DRZ. if you have a CDI box on your bike I would stay with a resistor plug so you don't get any interuption on your bike.
  4. #3
    Join Date
    Aug 2004
    Location
    Utah
    Posts
    2,684
    Default
    I have CDI but my manual states a non resistor plug so I don't know what to do. I read that resistors don't put out as much spark as a non.
    2005 CRF450X
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Oct 2005
    Location
    Arizona
    Posts
    39
    Default
    Resistor vs non resistor becomes very important when entering a very tight turn and the reception on your radio gets static. If you are backing it in and trying to retune your radio at the same time it could get hairy.
  7. #5
    Join Date
    Nov 2005
    Posts
    889
    Default
    +1 RC30GUY I had that problem also but I changed over to
    XM radio and on other days I use an MP3 player to solve such problems
  8. #6
    Join Date
    Nov 2005
    Location
    Bay Area
    Posts
    1,241
    Default
    Quote Originally Posted by Michelangelo
    id play it safe and just stick with what the manual says
  9.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
