Yamaha YZF150
Results 1 to 10 of 10
Thread: Yamaha YZF150
  1. #1
    Join Date
    Mar 2010
    Location
    New Holland, PA
    Posts
    166
    Default Yamaha YZF150
    Here is my Yamaha YZF150
    YZ85 chassis with a TTR150 (150 kit). 1 month build here at the shop with Dennis (head tech) and myself. Started with 12" wheels but ended working best with 17".
    Pretty fun build and it looks pretty factory and unnoticeable unless you know what your looking at. Runs really strong and handles like a dream. So lightweight and can you brake deep into corners!!! No I am seeing what I can put the YZ85 engine into...hmmm.
    Robert Miller "A Brand You Can Trust"
    "Support the Shops That Directly Support Your Fun!"
    Owner www.TheServicePavilion.com
    Most Specialized Arai Helmets Dealer in the Americas
    TTR50-TTR84(x2)-TTR90(X7)-YZF150-YZ125-YZR50-TTR125(x2)-YZ250-YZ60-YZ85-YZ105-YSR50(x2)
  2.
    Advertisement
  3. #2
    Join Date
    Aug 2005
    Location
    Athens,Alabama
    Posts
    1,342
  4. #3
    Join Date
    Jan 2007
    Location
    Staten Island, NY
    Posts
    890
    Items for Sale
    Default
    nice job muh man, did you use the yz's airbox? I guess you only had to make the front motor mounts, the rear engine hole mount worked out to be the same diameter? definitely factory looking
    NORTHEAST METZLER/PIRELLI SUPERMOTO TIRE DEALER
    WWW.HAMMARACING.COM
    CRF450R, KXF450, CRF100, CRF150F, CRF250R, '82V45 Sabre '00 Aprilia SR50, 82 Yamaha XJ650RJ Seca, '72 RD350 R5
    http://www.youtube.com/watch_popup?v=xdj67XknFrM#t=5
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Mar 2010
    Location
    New Holland, PA
    Posts
    166
    Default
    Thanks. Well none of the mounts worked out really. Front down tube of the frame was added and worked to use the stock holder. The back mount on a TTR does not have that large mount like YZ's do. So fabricated a carrier that used the Swing-arm bolt but then grabbed the rear mounts on the cases.
    It is the stock airbox, sort of...We flipped the rear shock around and then spun the airbox boot to be on the other side. But the airbox went through a lot of mods to make it all fit correctly, btu still using a stock filter in it.
    Thanks again.
  7. #5
    Join Date
    Apr 2010
    Location
    Louisville, KY
    Posts
    65
    Default
    Is that a stock 85 swing arm?
    Team Fastline
    DM40cc,GP6 50cc,YZ85Tard,YZ85dirt,250Ninja
  8. #6
    Join Date
    Mar 2010
    Location
    New Holland, PA
    Posts
    166
    Default
    Yes, that is the stock 85 swing arm. The 17" fits, not much room for moving the axle front to back for set-up. But I prefer the shorter wheel base over the "big wheel" set-up swing arm.
  9. #7
    Join Date
    Nov 2010
    Posts
    3
    Default
    This is such a surprising bike. It looks small but after reading capacity of engine of this yamaha YZF150 I believe that it is not small. I think it will runs strong and handles like a dream.
  10. #8
    Join Date
    Mar 2010
    Location
    New Holland, PA
    Posts
    166
    Default
    Thank you. This bike handles better then I had planned. The YZ 85 chassis is a race bike plan and simple. So it let's you get away with so many things on the track, because it was made to do that!
  11. #9
    Join Date
    Oct 2009
    Posts
    31
    Default
    This is a cool project. I am currently working on the same thing. I cann't wait to ride the thing.
    What are you using for a front brake set up?
  12. #10
    Join Date
    Apr 2008
    Location
    Tulsa
    Posts
    25
    Default
    Very Cool!
    09 CRF 150R Supermoto/Flattracker
    CRF 250R Supermoto~CRF250R Flattracker
    NSR/NSF100 4stroke ~ NSR63 2 Stroke
    XR/Takegawa/115 Flattracker
    XR100 Super X/with Works 85 Suspension
  13.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
